VideoHelp.com Forum
    Hi guys,
    Sorry if this has been answered before but I've searched everywhere and can't find an answer. I have two episodes of a series on a dvd menu but they are in the wrong order (the 1st selection is actually the second episode). I can get the selections to play the correct episode using Pgcedit, but the text on the selections still shows the wrong episode. The guide said to save the cell as a bitmap and then edit it, but when I preview the menu in programs such as Pgcedit the text isn't there - just the background. I can't see any more cells. Where does the text come from? Is it in another file somewhere that I can edit, or am I trying to do something that's impossible? I don't really want to do another menu because there are another 11 disks with the same menu and I can't replicate it.
    Please help guys, it's driving me nuts.
    John.
    If the text isn't there on a screen capture, then they probably used a subpicture with the text in it. Use SubRip to get the subpics as see if the text is there.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
    Thanks a lot SLK001. You're right, the text is there and I can save it as a bitmap to edit. Is there any program which will allow me to re-insert the edited bitmap back into the VOB easily, or do I have to demux the original VOB and then re-author with the new bitmap somehow. I'm new to this so I'm muddling my way through.
    John.
  4. Member daamon's Avatar
    I've never used it, but menuedit may be of use. Don't know...
    Good luck.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  1. DVD-Lab Pro: Subtitles change text
    By TheLaserdisc in forum Authoring (DVD)
    Last Post: 18th Aug 2010, 12:23
  2. Change PM notify text?
    By lordsmurf in forum Feedback
    Last Post: 10th Jun 2009, 20:14
  3. FAVC Menu Text
    By Soixante in forum Authoring (DVD)
    Last Post: 11th Jan 2009, 07:05
  4. Change a Text to Speech GPS into a I-pod Touch look alike
    By SingSing in forum Portable Video
    Last Post: 6th Apr 2008, 07:28
  5. Replies: 3
    Last Post: 9th Feb 2008, 11:43
