Hello.
I have severals samples in WMVHD how i can covert this shorts samples
in order to burn it into a DVD normal.
I want to keep the high definition because my DVD teorically it's a HD DVD and accept signals 720p and 1080i.
IS IT POSSIBLE????
THANKS
SORRY FOR THE POST I CAN'T DELETE IT NOW I HAD NOT READ THE STIK BEFORE
Use tmpgenc plus and convert to 1280x720 mpeg2. Burn the files on the dvd, you should not author.
but are you sure that you can play mpeg2 1280x720 on your dvd player? very few supports this.
Tell us the model of your DVD player.
DENON 2910
Do you tink i will be able to???
I am not sure of all if it supports the HD
no it does not support any hd format on dvd. you must convert to dvd.
shrinking mkvs and wmvhd 2 bluray...a little help please
By tomrip in forum Video ConversionReplies: 10Last Post: 30th Dec 2008, 19:59 -
mux 5.1 ac3 into wmvhd?
By nick101181 in forum AudioReplies: 5Last Post: 27th Jul 2008, 14:04 -
MKV/264 to WMV/WMVHD/ISO
By ironape2 in forum Video ConversionReplies: 2Last Post: 16th Oct 2007, 08:36 -
WMVHD Playback problem on a particular video
By huthmakerj in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 10th Jul 2007, 14:41 -
WMVHD files can't skip after half way...only on WMP
By aciras in forum Software PlayingReplies: 3Last Post: 5th Jul 2007, 09:31
