VideoHelp.com Forum
  1. I will be importing my recordings from a standalone recorder. I would like them to fit on a dual layered disc and create nice menus with names. I don't want to re-encode anything and want to keep it simple. I've played with dvd-labs which had a high learning curve. I would like something simple that would work with Dual Layered discs.
    In a nutshell:
    1. Want picture thumnail menus that can be named.
    2. No re-encode
    3. Must be compatible w/ dual layered disc
  2. Member Forum Troll's Avatar
    TDA 1.6 does all that. You might try it.
  3. Thanks, I've heard of it. Is it easy to use?
    Yes. Try the demo.
  1. Replies: 0
    Last Post: 26th Mar 2011, 14:39
  2. Replies: 3
    Last Post: 10th Nov 2009, 18:55
  3. DVD recorder truncates recordings
    By JosephWebber in forum DVD & Blu-ray Recorders
    Last Post: 4th Nov 2009, 10:49
  4. dvd recorder keeps destroying my recordings
    By postie1392 in forum DVD & Blu-ray Recorders
    Last Post: 13th Mar 2009, 07:30
  5. Problem ripping standalone DVD recorder disc
    By mojo in forum DVD Ripping
    Last Post: 28th Oct 2008, 23:33
