I copied a bunch of VCDs onto a DVD. i.e. popped in the VCD in the PC, dragged and dropped the various folders onto the DVD, preserving each top level folder as each VCD i.e. VCD1, VCD2 with all the original VCD folders under it.
I used VCD Easy to convert each .DAT file from the VCD into a MPEG file.
This MPEG1 file plays fine on the PC, but it doesnt play at all on my Prismiq Media Player which is supposed to play MPEG1 files.
AVICodec says the MPG files are fine.
Any ideas?
Thread: VCD .dat file to MPEG
use vcdgear (it's FREE!) to "extract" the video files from your VCD
drop the extracted mpg files into your favorite DVD authoring program (I like TMPGEnc DVD Author)
it's relatively quick & easy and I know it works perfectly because I converted my entire VCD library to DVD using this method"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!"
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 17:06 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 12:57 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 6th Nov 2008, 23:42 -
How to corp a dat or mpeg file to mpeg
By onlyrasel in forum VCDEasy GeneralReplies: 1Last Post: 26th Sep 2008, 23:18
Statistics
Newest guides
Latest tool updates
New media comments
