Use an all-in-one avi to dvd converer with subtitle support like divxtodvd, avi2dvd, thefilmmachine,diko or dvd2svcd.
or
Convert to dvd compliant mpeg and author with and authoring tool that support switchable subtitles like dvdauthorgui, dvd-lab pro, ulead dvd workshop.
I use iMovie and iDVD to transfer, edit and author DVDs. This suite doesn't support making switchable support. Is there any way that I can add subtitles to video during this method and then author using iDVD?
PC program is fine as well. to do this intermediate job.
I prefer iLife suite only because the DVD templates that iDVD has are simply awesome.
Many thanks in advance -
I'm trying to use Tsunami-MPEG DVD Author Pro which is now known as TMPG DVD Author 2. I like this program because of the menus are easy to make and it's just a basic menu. I'm trying to use DVDlab-Pro to add switchable subtitles. But I can't seem to make the same basic menu I can when using Tsunami. On Tsunami I have it to where I have the main menu and the track menus. Each track menu only has 1 video and a different back ground. But on Tsunami I can use the background at only 91% of the original size of the photo so it shows the whole thing on the part that shows where it would be on the tv. On DVDlab it automatically stretches the picture out which I don't want. Is there anyway I can add the create the menu using Tsunami and then add the subtitles using DVDlab pro later on or something like that. I really need help.
divxtodvd is now called convertXtodvd. freeware is dvdflick
And baldrick, that guide with DVDlab pro is outdated! could u please update to version 23?looking for subs: Höök tt0997023 - Lime tt0269480 - Desideria tt0081724 Mafiosa tt0807686 La clé sur la porte tt0077348 tt=iMDb.com
iPod touch video with switchable subtitles
By txporter in forum SubtitleReplies: 5Last Post: 13th Jan 2011, 15:35 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 12:52 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Creating a DVD with Menus and switchable subtitles on Mac OS X
By koke_broke in forum MacReplies: 7Last Post: 27th Mar 2009, 12:43 -
How do you add switchable .idx / .sub to dual audio .AVI (XviD)?
By NextJinGamer in forum SubtitleReplies: 4Last Post: 1st Jul 2008, 16:42
