Read http://forum.videohelp.com/topic338721.html for a detailed guide using only free tools.
Some older methods:
http://www.videohelp.com/guides.php?...elect=5;20#598
and
http://www.videohelp.com/guides.php?...elect=5;20#706
and
http://www.videohelp.com/guides.php?guideid=815#815
Closed Thread
Hi: when I opened the video and audio file to import them only m2v file are import I had error and worning about import vob file .the error are :1-cause: wrong espect ratio 2-size 1365x1.fps:29.97aspect .my video region is 2 .plz what can I do to avoid this error.
In anathor step when I hit the ( generate subtitle stream) new window appeares it have same name( generate subtitle stream ) it ask me to hit save file name as ( *.sp1 ) but when I save or close this window the generat subtitle stream failed.....plz explane this problems .
What guide are you following?
What software says that error? subtitle creator?
the program is dvd lab pro 2.5
Hi ... can I get Regisration for dvd lab pro 2.5
No Problem About Using dvd lab pro 2.5 .... No Error ...Thank You
Hi..... i want to know about:-which software can i use to get (SRT)file from movie with english language with all thanks.
Hi..... i want to know about:-which software can i use to get (SRT) file from dvd with no subtitles but with english language ... thanks.
Make a new topic instead. I'm locking this one.
How to add new subtitles to an existing DVD
By Baldrick in forum User guidesReplies: 354Last Post: 28th Mar 2012, 01:51 -
How to add subtitles permanently to existing mp4 h.264 file???
By Patrick_H in forum SubtitleReplies: 7Last Post: 8th May 2011, 21:23 -
Add subtitles to existing dvd movie
By woodtogo in forum SubtitleReplies: 13Last Post: 20th Apr 2011, 17:55 -
How do I add new subtitles to a existing BLUE RAY
By siopilos in forum SubtitleReplies: 1Last Post: 12th Nov 2009, 09:48 -
How to add new subtitles to an existing video DVD?
By Newsense in forum LinuxReplies: 4Last Post: 18th Sep 2008, 17:08
