I know this doesn't relate to the question but I have also run into this problem and in my opinion it is a lot easier to find other subs. I tried baldrick's suggested siites and they worked good you can also search multiple specific sites on google with the format site:example.com OR lies.com after the search term. I use this when searching multiple sites for subs all the time. Here is what I use: site:http://www.opensubtitles.org/en OR http://subscene.com/ OR http://www.podnapisi.net/ OR http://www.subtitlesource.org/ OR http://www.divxstation.com OR http://www.divxsubtitles.net OR http://www.subbiee.com
Results 61 to 67 of 67
yagokoro: One post is enough. If you continue post = SPAM.
Yep; AviDemux2 (for Mac) did the job exactly as advertised. Thanks.
Hi Miles,
I was searching and I saw your post for Converting IDX/SUB to SRT ... well, I tried it as follow ...
1) Use SubToSup ... and convert the IDX to SUP
2) Load up the SUP in DVDSubEdit ... but then it asks me for IFO ... well since my Subtitle is from an AVI file I skip this ...
I run the OCR ... and then Push ".srt" Button and save the Output as SRT.
Now, here is my problem ... the SRT subtitle does NOT SYNC with the Video!!!
Q1: Can you tell me what I am doing wrong? Or how can I get it Right?
Thanks,
G!
Do the VobSubs (IDX/SUB) synch with the video? If so, maybe try converting the VobSubs to SUP using SubtitleCreator.
Hi Manono,
Yes the VobSubs (IDX/SUB) do Sync with the video ... OK, I will try SubtitleCreator and report back!
THANKS,
G!
^^ Hi Manono,
Wow ... your suggestion worked like a charm ... now my output SRT is in Sync with the video.
Thanks again!
G!
How to extract subtitles from a Blu-ray and convert to srt or sub/idx
By Baldrick in forum User guidesReplies: 16Last Post: 18th Mar 2012, 20:08 -
Convert .sub, .idx to .srt subtitles?
By Ryu69 in forum Video ConversionReplies: 17Last Post: 9th Jul 2011, 04:23 -
How do I convert DVD to sub/idx or text srt COLOR subtitles?
By kkm in forum SubtitleReplies: 1Last Post: 19th Mar 2010, 13:08 -
.SRT (text) to .SUB/.IDX (image) subs
By Sheavi in forum SubtitleReplies: 7Last Post: 29th Dec 2009, 03:42 -
Some questions to the topic/Guide How do I convert DVD or sub/idx to text..
By aslan in forum SubtitleReplies: 5Last Post: 5th Jan 2008, 18:30
