VideoHelp.com Forum
  1. Member Sifaga's Avatar
    I am buying a harddrive and RAM for a mate
    what software can i use to find out what type of ram to get. SD Ram or DDR Ram
    can this software tell me if it will support a 160gig harddrive as well
    he is running windows 2000
    i can open it and look , but i dont know what Im looking for
    Will that SiSoftware Sandra do it for me
    thankyou
  2. Member ViRaL1's Avatar
    The easiest way to tell physically is that DDR has one notch in it and SDR has two notches. Sandra should also be able to tell you. Without opening it up though, you can download CPU-Z
    http://www.cpuid.org/cpuz.php#download
    and click on the memory tab.
    Nothing can stop me now, 'cause I don't care anymore.
  3. Member Sifaga's Avatar
    Cool,
    I downloaded CPU-Z and its a nice bit of software
    the one notch two notch description helps, i'll open it up and have a look
    using CPU-Z at work it says that i have DDR-SDRAM, which is confusing, but I'll just open it and check how many notches.
  4. Member ViRaL1's Avatar
    DDR-SDRAM or Double Data Rate Synchronous DRAM is what people refer to as DDR. It's all technically SDRAM, but when people say SDRAM, they usually mean Single Data Rate or NON-DDR SDRAM.
  5. Member Sifaga's Avatar
    Ok Cool
  6. VH Veteran jimmalenko's Avatar
    We probably shouldn't ever discount reading the motherboard manual either. It will tell you in there whether the MB supports SD and/or DDR (it could well support both).
    If in doubt, Google it.
  7. That CPU Z is a nice tool. I learned I had a stick of PC2100 and PC 2700 installed after I bought a "matched set" off a guy here...
  8. Member Sifaga's Avatar
    hey Jim thats abit drastic
    when all else fails read the manual
    i think its probably still in the plastic it came in
    taking a look inside and using CPU-Z , i think i should be right finding out what ram to get.
  1. Problems copying .VRO files from DVD-RAM -- SOLVED!
    By usually_quiet in forum DVD Ripping
    Last Post: 2nd Jun 2011, 16:30
  2. Value ram
    By jollyjohn in forum Computer
    Last Post: 5th Mar 2011, 06:21
  3. RAM!!
    By HotDamn! in forum Computer
    Last Post: 15th Dec 2009, 07:43
  4. [solved, kthx]4GB of RAM not recognized in XP Home SP2
    By doomdoomdoom in forum Computer
    Last Post: 11th Dec 2007, 04:04
  5. Question about refreshing DDR RAM for video application.
    By SingSing in forum Video Conversion
    Last Post: 13th Aug 2007, 10:41
