VideoHelp.com Forum
  1. Hi
    Does anyone know the best software to do this and which format should I use in order to save on size but not too much of a decline in quality?
  2. Member Soopafresh's Avatar
    The "Best" Software
    WaveLab or Soundforge
    BBE Sonic Maximizer DirectX Plugin
  3. Member mats.hogberg's Avatar
    Decode to wav, reencode to MP3 at a lower bit rate. What tools you use won't affect quality that much, but I prefer lame for mp3 encoding.
    If your player handles .ogg, try ogg at a really low bitrate, like 48 kbps. Sounds surprisingly good (I use it in my cell phone, where I'm limited to a 16 MB mem stick).
    /Mats
    No need to decode to wav as lame supports mp3 input unless you compile with --disable-decoder. Think I posted a script somewhere around here to re-encode all files to a mirror directories and copy the original id3 tags over.
  5. Where can I download Lame? What is that script about?
  6. Member MOVIEGEEK's Avatar
    CDex can batch encode,get the latest LAME here:
    http://rarewares.org/mp3.html
  7. Use an encoder that uses Lame if you want to reconvert to a lower bitrate MP3.
    Other options include OGG, WMA or even Apple's AAC.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  1. Anyone know of a good MP3 program to resize (make smaller) some files
    By soulbug in forum Newbie / General discussions
    Last Post: 28th Feb 2011, 15:03
  2. Replies: 6
    Last Post: 11th Aug 2009, 12:08
  3. Trouble converting AVI(divx)+MP3 to FLV+MP3
    By BLboy in forum Video Conversion
    Last Post: 21st Jul 2009, 04:36
  4. wma to mp3 errors; losing file size on conversion
    By gidget00 in forum ffmpegX general discussion
    Last Post: 22nd Aug 2008, 18:48
