Hey all,
I have created a motion menu and placed it into Dvd-Lab. I then placed my own custom buttons on top of that menu and added links to them. However when I run it in simulate OR when I do a test compile, those buttons (and the text with them) just show up as gray circles and gray text. If I change the color map slider all the way to the right, they end up solid white (or whatever color I choose) or if it's to the left, they all disappear. Can what I what to do be done?
CCRAMan
All you have created is the subpicture, which is only one colour. If you want to have permanent text you need to put the text on the background without links, then render motion out to an avi, then reencode it, bring it back and put the subpictures on it.
Motion Menu Buttons
By lapetite_66 in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2009, 15:45 -
DVD-Lab Pro 2, making shaped buttons from parts of menu background?
By bizzybody in forum Authoring (DVD)Replies: 0Last Post: 24th Dec 2008, 19:06 -
Creating buttons on a motion menu
By jrd3263 in forum Authoring (DVD)Replies: 2Last Post: 16th Nov 2008, 16:13 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
DVD Motion Menu Buttons (Free & Easy)
By ImaWeTodd in forum User guidesReplies: 31Last Post: 28th Jan 2008, 16:12
Statistics
Newest guides
Latest tool updates
New media comments
