VideoHelp.com Forum
Results 1 to 9 of 9
  1. [url=http]text[/url] Denvers Dawgs's Avatar
    Is it possible to format an external hard drive to win98 and then transfer those files over to a XP system? 98 is fat32 xp is ntfs?
    I ask because I already have a nfts formatted external, but it won't work with the 98 system. would nfts system be able to see fat32?
    What We Do In Life, Echoes In Eternity....
  2. Member Soopafresh's Avatar
    XP Can See Fat32 and NTFS
    98 Can Only See Fat32 (and FAT)
    Your external drive would have to be formatted for Fat32 in order to be swapped between both systems.
  3. [url=http]text[/url] Denvers Dawgs's Avatar
    great thanks......
  4. Member pfh's Avatar
    FYI- I have an external with 2 parttitions. One is NTFS and the other is fat32. The fat32 part. has some older apps. that work under my XP main drive if that's what you are trying to do.
  5. I suggest that DD do what PFH did...add a partition to the external and format it with FAT32. You might have to use Paritition Magic to allocate the space and create the partition, but you wouldn't have to reformat.
  6. [url=http]text[/url] Denvers Dawgs's Avatar
    the drive is empty and is only 12gb so I don't mind reformating. Can I reformat it to fat32 using the xp system?
  7. Yeppers...go for it.
    During the format process, it will ask you what file system to format to (or, you will select the file system you want).
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  9. [url=http]text[/url] Denvers Dawgs's Avatar
    great thanks again for the help.....
  1. blu ray hdd- external hdd
    By jayjay97 in forum Authoring (Blu-ray)
    Last Post: 25th Sep 2010, 00:35
  2. Replies: 0
    Last Post: 18th Mar 2010, 12:24
  3. Connecting HDD to PC - Transfer Movies
    By ZiGGY909 in forum DVD & Blu-ray Recorders
    Last Post: 1st Mar 2009, 13:38
  4. HDD Files transfer without PC
    By balebob in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 19th Feb 2008, 11:59
  5. HDD transfer/copy ?
    By popgun in forum DVD & Blu-ray Recorders
    Last Post: 30th Sep 2007, 13:40
