Hi all,
As the title says, I have three separate commentarys for a movie and would like to have a menu whereby you can choose to have each commentary as the only audio stream with the movie playing. Is this possible in DVD Lab Pro?
I've searched the site and Google for instructions on replacing the audio stream with another file but can't find them
Thanks a lot in advance.
You don't replace the audio, you put all four audio tracks in the movie asset, then use a menu to choose which one to listen to at the time.
This is the tutorial at the Mediachance site (makers of DVD Lab Pro) showing how to create a manager menu for choosing audio tracks. It also includes subtitles, but you can ignore that bit.
http://www.mediachance.com/dvdlab/tu.../amanager.html
I've read the above help bit which is what i want to do, but still don't understand what it wants me to do...at the moment i have three buttons all of which I want to point at the same movie but using a different audio stream. I can't seem to do it, as I'm not sure
a) where the menu links to (is it the VM command?)
b) what the VM code should be for three audio streams
(is it?)Code:GPRM0 = SPRM1 GPRM1 = 1024 if (GPRM0 == 1) GPRM1 = 2048 if (GPRM0 == 2) GPRM1 = 3072 if (GPRM0 == 3) GPRM1 = 4096 SetHL_BTN GPRM1 Break
c) which audio stream is which, and how to tell this in DVD Lab Pro's right click -> Link -> Set Audio menu.
Sorry for the long question but I hope i've made myself clear with it.
MSN Messenger : stokefan@hotmail.com
MPEG Streamclip:DVD is ripped with commentary audio stream
By camilla89 in forum DVD RippingReplies: 0Last Post: 29th Aug 2010, 09:43 -
How can I add an audio commentary to a dvd?
By artyjeffrey in forum Authoring (DVD)Replies: 1Last Post: 28th Nov 2009, 03:44 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
replacing audio on a dvd
By phillbrett68 in forum Authoring (DVD)Replies: 10Last Post: 11th Dec 2008, 00:11 -
how to add commentary over dvd audio?
By Denvers Dawgs in forum AudioReplies: 3Last Post: 23rd Nov 2007, 23:58
Statistics
Newest guides
Latest tool updates
New media comments
