VideoHelp.com Forum
  1. I recently bought TMPGEnc Xpress 3.1.5.82.
    Does this program need to be installed on the MCE 2005 pc for it to convert DVR-MS files? I do all my editing/conversions on my dual processor workstation XP Pro SP2 machine. I installed it on that machine and tried to load the DVR-MS file. All I get is a green screen and no audio. I am able to play it on WMP 9 but it won't work in TMPGEnc Xpress.
    Pegasys' website says it does support DVR-MS, so I must be doing something wrong. I need some help, thanks.
  2. There should be a radio button on the program that allows you to go into a "Source Wizard"
    In the source wizard the third option allows you to convert a DVR-MS file into mpeg1 or 2. TMPEGEnc can not work with DVR-MS files, but it can convert it to file like mpeg1 or mpeg2 so that you are then able to edit the source file.
    Hope this helps.
  3. That sure did help. Thank you very much
  1. Replies: 6
    Last Post: 24th Jun 2011, 15:42
  2. Replies: 6
    Last Post: 23rd Feb 2011, 01:37
  3. TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
    By artyjeffrey in forum Authoring (DVD)
    Last Post: 8th Nov 2008, 13:23
  4. Replies: 1
    Last Post: 20th Aug 2008, 02:41
  5. Replies: 5
    Last Post: 18th Nov 2007, 15:07
