i'm just wondering if anyone knows how to burn subtitles that are separate from .avi file, that is they have a separate .sub file, together with the .avi file?
thanks![]()
kat
Thread: burning subtitles
Kat
Don't know if understood correctly. You start your burning programm, import the avi and the sub file with the same name and *.sub (or whatever is) extension, burn disc at once - ready.
i'm using nero vision express 2, but it doesn't let me import the .sub file.
Kat
What I said is "start burning programm". You should answer for yourself the following question: "Is Nero Vision Express 2 a burning program?".
The second possibility is you didn't ask the right question in your first post.
Exactly. What you should have asked is how to convert and avi with a seperate sub file.
Anyway NVE uses directshow so if it plays with subs, it should also convert with subs.
ah yes sorry i wrote it pretty late last night.
is it possible to convert .avi and it's separate .sub file so that it ends up being a hard subbed avi file using NVE2?Kat
install vsfilter or vobsub and try nerovision express. you should see the subs when playing the video with windows media player, www.videohelp.com/play#subs
Burning movies with subtitles?
By legenderycity in forum Authoring (DVD)Replies: 9Last Post: 29th Jan 2010, 08:32 -
Burning subtitles to video
By nikitar in forum ffmpegX general discussionReplies: 2Last Post: 4th Oct 2009, 18:02 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28 -
how to remove subtitles before burning to DVD
By ouiglz in forum SubtitleReplies: 5Last Post: 20th Jan 2008, 08:31 -
Subtitles and codecs for burning
By vipertongn in forum SubtitleReplies: 0Last Post: 17th Aug 2007, 17:23
