I often had this problem...
when I split a 1.2G mpg movie ( converted from a 1.2G avi file ) files into two parts, there will be errors. when I test the mpeg o/p in VirtualDub. It will say - discontinuous timestamp found in video stream 0 at byte..... This may indicate any improper join. if I burn that in vcd, the dat will have pauses and pixel errors in the movie.
sometimes I reencode the split "problem" mpg files using Tmpgenc...and then the mpg files is ok again but this does not always work.
if I split the 1.2G avi files first into two and convert the 2 into mpg then there will be no errors.
any ideas why?
tks.![]()
Fact is stranger than Fiction
What tool do you use to split the mpg? The proper procedure is not to split, neither source nor dest. If you're using TMPGEnc and loading the source AVI directly, set the source range and encode in two "sessions". If frameserving from VirtualDub, set the range in VirtualDub.
/Mats
I use Easy Video Splitter to split mpg...TMPGEnc can do that? - load the AVI and instruct it to encode and split at 2 selected parts...
Click the "Settings" button. On the "Advanced" tab, Double click "Source range". For first "pass", set start frame to 0, end frame somewhere half way. Encode.
Repeat, but set start frame to the same as end frame from first pass, set end frame to last frame. Encode again.
/Mats
I dont know about Easy Video Splitter but I have been using AVI-MPG-WMV splitter from boilsoft. I never got any problem with that. Check this out
http://www.boilsoft.com/videosplitter/When I was born I was so shocked that I could'nt speak for 18 months.
How do I keep DV files from splitting ?
By RWANDREWS in forum CapturingReplies: 3Last Post: 15th May 2010, 03:07 -
How to test MPG files for errors?
By madmartian in forum Software PlayingReplies: 1Last Post: 17th Jun 2009, 14:30 -
splitting wmv and mpg at time codes
By silverbullet69 in forum Newbie / General discussionsReplies: 4Last Post: 19th Mar 2009, 02:42 -
Converting and splitting 2GB MPG file
By mohalfares in forum Video ConversionReplies: 3Last Post: 2nd Sep 2008, 12:47 -
Splitting and Joining then Converting VOB > MPG > FLV
By deportu in forum Newbie / General discussionsReplies: 7Last Post: 12th Jun 2008, 21:32
