Hi guys,
I've got myself a Belkin bluetooth dongle for my PC, and I have successfully connected it up and paired with my Logitech Mobile Freedom headset. I can hear sounds out of it, but I have discovered that the microphone volume is far too low.
I have been into the advanced audio properties, and Bluetooth audio doesn't appear to have a "Mic Boost" option on it as my normal audio device does. I have tested the microphone, and it picks up sound when you tap on it but isn't sensitive enough for voices.
It works perfectly with my mobile, so I know the headset is OK.
I'd really appreciate any advice or solutions anyone might have.
Many thanks,
Cobra
Only thing I could think of would be a registry tweak to increase the volume of the input device. Which key to modify is the question. You can determine the registry keys being accessed by loading REGMON from http://www.sysinternals.com .
This product MIGHT be interesting (and applicable ?)
http://www.avelink.com/Bluetooth/Products/AudioDriver/
While unrelated to your specific headset, I found a thread about tweaking volume levels on another bluetooth device. Perhaps there are some hints that might be applicable to your situation.
http://www.howardforums.com/showthre...hreadid=494297
Whoops....
Got it. Still having some (unrelated) trouble, but it does work and people can now hear me.
Thanks, Soopafresh! I appreciate your help.
Cobra
i also have a Logitech Mobile Freedom headset hooked thru my computer but people say they can hear me pretty good when i talk thru my stanaphone software. My question is everytime you cut your headset on do you have to enter the code????? and if so do it take a couple times for it to connect???????
How do you get a bluetooth headset to play system audio - passkey
By yoda313 in forum ComputerReplies: 0Last Post: 3rd Jan 2010, 14:01 -
bluetooth headset as mic
By stoudtco in forum AudioReplies: 0Last Post: 15th Nov 2009, 09:58 -
Using the line in port on my G5 with a headset mic...no audio
By Huntr777 in forum MacReplies: 6Last Post: 9th Nov 2009, 15:45 -
Nokia BH-905 Bluetooth Headset Debuts
By G)-(OST in forum Latest Video NewsReplies: 1Last Post: 12th Jun 2009, 06:39
