Hi major.
Just tried to install ffmpegX on my machine running OSX Tiger (8A428).
The following messages prevents me from installing succesfully:
##/bin/sh: line 1: cd: /usr/local/share: No such file or directory
I´ve already repaired disk permissions, no success.
Maybe we need a small fix in the installation script?
Regards, Caozinho
Results 1 to 25 of 25
Thread: Installation error under 10.4
Rip different
Tiger will be available on april 29. Version 0.0.9t of ffmpegX will be released subsequently, to handle an installation procedure suitable for Tiger.
In the meantime, you can make 0.0.9s work on Tiger by running the following command in /Applications/Utilities/Terminal.app:
sudo mkdir /usr/local/share
Type your login password blindly when requested. Then run again the ffmpegX installer.
Thank you major.
This is really incredible. Everybody is talking about Dashboard and Widgets, but ffmpegX unveals the real power behind Tiger. Just did a quick encoding test to realize it is about 15-20% faster on a PB G4/667 than running with Panther.
GreatRip different
I must be dumb. I just get:
mkdir: /usr/local: No such file or directory
After using the command:
Any ideas?
BlueFrog
I've got the same message. Can someone explain how to install, please. Thanks
Then copy/paste the following in Terminal.app
sudo mkdir /usr/local ; sudo mkdir /usr/local/share ; sudo mkdir /usr/local/lib ; sudo mkdir '/Library/Application Support/ffmpegX'
Then run again ffmpegX and proceed with installation.
I obtain this message in terminal : Last login: Fri Apr 29 21:30:03 on ttyp1
Welcome to Darwin!
[G4:~] mfmourgu% sudo mkdir /usr/local
mkdir: /usr/local: File exists
[G4:~] mfmourgu% sudo mkdir /usr/local/share
mkdir: /usr/local/share: File exists
Then when I launch the install of ffmpeg, I've got this alert :
the installation wa not successful. ##cp:/Library/Application Support/ffmpegX/mpeg2enc:no such file or directory.
Then type sudo mkdir '/Library/Application Support/ffmpegX' in Terminal and run again.
Thanks, Major, it works !
for me it worked but i have to reinstall mencoder every time i launch the app???
also using new tiger...
thxxx
Is your mencoder 6636100 bytes in size? If not then it is a wrong version.
but thats the mencoder file that i downloaded from your link ffmpegXbinaries180105
so whic version did i have 2 use??
greetz
jt77
ffmpegX 0.0.9s uses ffmpegXbinaries230105. Follow the instructions at http://homepage.mac.com/major4/download.html
I can't too instal ffmpegX in Tiger.
I get this message "##cp: /Library/Application Support/ffmpegX/mpeg2enc and /Library/Application Support/ffmpegX/mpeg2enc are identical (not copied)."
It appears you already have mpeg2enc. Don't install it again then.
I had same trouble in OS 10.3.9 before and 10.4 yet.
I found one think that helped me fix it:
I downloaded all binaries again from links, that showed ffmpegX and replaced.
And that fixed.
HiOriginally Posted by major
I was wondering when will this T version come out, I am stuck here, I cannot get any of my home movies done in Divx...
Any ideas when it will be out??
-Thanks
be patientOriginally Posted by drd1812
http://www.videohelp.com/forum/viewt...265e73#1309052
cool... thanks
As for the missing mencoder. I have the same problem on my fresh Tiger install.
I created the necessary folder (see mkdirs above) and then I've downloaded the latest releases located all 3 files - install went smooth. When I reopen FFMPEGX it asks for mencoder again.
Hopefully that issue will be reolved in the next release coming up any day now, right?
BTW, I don't mean to complain all the time. FFMPEGX is a great programm and I want to thank major for his continued support.
globo
If it asks for mencoder again, check if your mencoder is 6636100 bytes as the correct version should be.
You know, since I have been waiting so damn long for a fix to this problem, I have found another application that does the job I need. It is called HandBrake 0.7.0 and it works like a charm. No problems it is fast and effective. While I liked FFMPEG, I have to be honest, I feel really let down. To be concentrating on a release so far into the future, and have people hang with this damn problem is not very wise...
But at least there is always some other application that works for your benefit.
too bad cause I really liked ffmpeg.
There is no big problem with version 0.0.9s, and I had no consistent report of any problems on Tiger apart the need of creating a couple directories by hand. Release of 0.0.9t has taken some time because of ongoing work on version 1.0.0, which counts already over 20 000 lines of code.
If you have a problem with 0.0.9s, you should send a clear report of which error/issue it is, either here in the forums or preferably by email to major4@mac.com together with a screenshot showing any errors, and I can tell you that in 99% of the cases the issue can be resolved in minutes.
Zwei-Stein installation error.
By sjs in forum EditingReplies: 2Last Post: 1st Feb 2011, 14:30 -
Installation error
By johnsonk in forum ffmpegX general discussionReplies: 2Last Post: 14th Aug 2009, 11:05 -
Installation Error In Leopard
By Lefty! in forum ffmpegX bugs and suggestionsReplies: 3Last Post: 6th Dec 2008, 04:14 -
vegas 6.0 installation error
By scd250 in forum Software PlayingReplies: 3Last Post: 27th Feb 2008, 21:09 -
Installation error -
By ruggerjvd in forum ffmpegX bugs and suggestionsReplies: 4Last Post: 12th Nov 2007, 09:06
