its abunch of clips, how do i do it so that I get a preview of each video instead just parts of the one clip?
Results 1 to 10 of 10
Look at Render Motion in the hlep file. It explains how to set the length of each clip.
ya but do i put each clip as a movie?
Yes.
Cheers, Jim
My DVDLab Guides
how do u put mp3 into the menu backround...
i.e convert mp3 to proper format?
You need to convert it to the same audio format as used on your music clips. MP3 is not permissable, and DLP won't reencode it for you unless you have the tmpgenc AC3 encoder. If you don't want AC3 output then this won't help anyway.
You should have started with a simpler project in a simpler package.
ok i fugured out how to convert the mp3 to ac3.
but now in the preview screens when the video loops so does the audio?
That's DVD spec.
If you want the video to run the same length as audio on a menu, you need a longer video.
You could also duplicate the video as many times as needed, and join them all into one repeating video.Cheers, Jim
My DVDLab Guides
no i want the whole song to play and not loop when the 30second preview loops?
I just explained that you can't.
If you want the whole song to play, you need to have video the same length.
If you don't have a video that long, just duplicate the one you have, and join the two together, so the video is now double length. If that's not enough, dupe the video and join again, now it's 4x longer. If that's not enough, repeat as needed, until video is the same length as audio.Cheers, Jim
My DVDLab Guides
Just want the video clip using DVD-lab PRO 2
By WTRanger in forum Newbie / General discussionsReplies: 13Last Post: 29th Oct 2010, 05:18 -
DVD-Lab Pro 2: How to set a looped video as background of a menu?
By Stern77 in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2010, 11:00 -
video tutorial dvd-lab pro
By waefwaeefwaefw in forum Authoring (DVD)Replies: 1Last Post: 27th Oct 2008, 10:53 -
video size quadruples in dvd lab pro
By YOURCONNEXX in forum Authoring (DVD)Replies: 1Last Post: 13th Mar 2008, 19:23 -
loop entire video in dvd lab pro?
By sarcastik in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2007, 19:04
