VideoHelp.com Forum
Results 1 to 12 of 12
  1. Banned
    i want to know what DVD-ROM drive rips dvd's the fastest. i have a BenQ 1620 with the speed patch but i dont want to ware out the laser.
    Hey I'm looking for an answer myself. I want to know if the BenQ 1625 is faster than the 1620. Hopefully someone answers.
  3. VH Veteran jimmalenko's Avatar
    It's been generally accepted around here that the LiteOn DVD-ROMs seem to consistently sustain the fastest rip speeds. I have a 167T and 166S, both firmware-flashed with firmwares from http://forum.rpc1.org/dl_all.php and they can normally sustain anywhere between 6-12X on SL DVDs, and 6-10X on DL DVDs, maxing out at 15X on some DVDs.
    If in doubt, Google it.
  4. Mod Neophyte Super Moderator redwudz's Avatar
    Most DVD-ROMs rip at the same speed, though there are always exceptions. I have a Sony DDU1613 that works well and a older Toshiba SD-1212 that both rip at the same speed.
    Here's a discussion thread about DVD-ROMs that mostly relates to bad media reading, but may give some useful information: http://www.videohelp.com/forum/viewt...ghlight=dvdrom
    jimmalenko - what about this Lite-On SOHC-5232K? Have you heard of it and is it ay good?
  6. VH Veteran jimmalenko's Avatar
    can't say I have.
    Just did an all-forums search on "fastest dvd-rom", and found these:
    http://www.videohelp.com/forum/viewtopic.php?t=252328
    http://www.videohelp.com/forum/viewtopic.php?t=248406
    http://www.videohelp.com/forum/viewtopic.php?t=246965
    http://www.videohelp.com/forum/viewtopic.php?t=241004
    http://www.videohelp.com/forum/viewtopic.php?t=232582
    http://www.videohelp.com/forum/viewtopic.php?t=187112
    http://www.videohelp.com/forum/viewtopic.php?t=208367
    http://www.videohelp.com/forum/viewtopic.php?t=189457
    You'd think at least one of these threads might have some useful information.
  7. Member kato51's Avatar
    I think you need to use IE to view their page correctly.
    http://cdspeed2000.com/go.php3?link=dvdresults.php3
  8. Member richdvd's Avatar
    I have the 166S also...and it is very quick.
  9. Member chas0039's Avatar
    Stick with the answers at your post on CDfreaks. The 166 and 167 Liteons are discontinued, though either will do almost as well as the AOpen 1648 as long as you get the firmware from http://codeguys.rpc1.org/firmwares.html
    Still a few bugs in the system...
  10. Member MOVIEGEEK's Avatar
    I have one and it's fastVD-5=14x,DVD-9=8x
    Get the hacked firmware and it can rip a DVDR at 14x.
  11. There is a black sony model at newegg, I'll look up the link when I get the chance, that happens to be a rebadged Lite-on 167T if thats what you are looking for. The newegg ratings on the newer lite-on drives are not nearly as good as the older ones. Not that that means a great deal.
  12. The Aopen 1648 is faster than any of the Liteons. I've got a Liteon 163 and it's quick, although my hacked Benq 822 is a little faster.
  1. Replace dvd drive with dvd-rom drive.
    By jtrapat1 in forum DVD & Blu-ray Players
    Last Post: 25th Dec 2008, 10:33
  2. Replies: 15
    Last Post: 24th Dec 2008, 17:19
  3. Suggestions for a new, low priced DVD-ROM drive...
    By i am x in forum DVD & Blu-ray Players
    Last Post: 15th Mar 2008, 22:03
  4. Help on Choosing a DVD-Rom Drive
    By scustalow in forum DVD Ripping
    Last Post: 13th Jun 2007, 11:04
  5. hd-dvd rom drive
    By computerchuck in forum Software Playing
    Last Post: 8th May 2007, 07:55
