To record DVD -RW does the blank media have to specify -RW on the package or can you use +RW?
If you have a dvd writer or recorder that can only burn -RW you must get -RW, it wont work with +RW.
I bought the Sony RDR-VX500 which is RW+-. So could I use +RW packaged blank DVDs to record as -RW?
What do you mean by "as -RW"? Why not just burn as +RW?
My understanding is that -RW will let you make multiple recordings without reformating and erasing other recordings where +RW reformats each time, therefore erasing any previous recordings on the DVD.
Easy answer no. If you want -RW disks you have to buy -RW disks. they are different and not interchangable. It is the design of the disk that makes it what it is, not how it is used.
Cheers
How record DVR video?
By mikehende in forum Newbie / General discussionsReplies: 1Last Post: 15th Nov 2011, 08:27 -
My first post: connrccting a DVD to a comcast DVR to record from ther DVR
By retired_guy in forum Newbie / General discussionsReplies: 10Last Post: 24th Jul 2011, 18:54 -
Best Way To Record Shows from DVR to DVD?
By Stunner in forum Newbie / General discussionsReplies: 32Last Post: 10th Mar 2011, 17:42 -
record from DVR?
By merc68 in forum Newbie / General discussionsReplies: 2Last Post: 11th Nov 2009, 13:05 -
Record HD from a Comcast DVR?
By elister in forum DVB / HDTVReplies: 15Last Post: 10th Dec 2007, 17:11
