VideoHelp.com Forum
    Hi I would like to put a video together with clips I recieved over internet etc. What would be the easiest program to use? I tried windows movie maker, but it is not that great. Now dling Avid DV.
  2. Member daamon's Avatar
    What format are the clips in: MPEGs, AVIs (Divx, Xvid, DV etc.), MOV etc. etc.?
    Use GSpot (beta v2.52) or AVICodec to get info on files.
    What kind of editing do you want to do: trimming or transitions and effects?
    Do you want to add audio?
    More info...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. The Old One SatStorm's Avatar
    To join files to put them on the same directory, they need all to be
    a- of the same type
    b- of the same framesize
    So, you encode them all to something same and that way you have them all together
    Please try post in correct forum. This is no capturing. Use the general forum if you don't where to post. Moving you.
  5. The Old One SatStorm's Avatar
    You beat me on this for seconds!
  1. Which program I should use for video editing?
    By Shigatsu in forum Newbie / General discussions
    Last Post: 15th Jun 2011, 11:09
  2. Recommended video editing program?
    By Hiku in forum Editing
    Last Post: 13th May 2010, 15:16
  3. Trying to find a video editing program
    By LOGiC in forum Newbie / General discussions
    Last Post: 2nd Nov 2009, 20:37
  4. Free video editing program - which one?
    By tealgrey in forum Mac
    Last Post: 24th Apr 2008, 18:59
  5. Video Editing Program for VHS
    By socool135 in forum Restoration
    Last Post: 20th Jan 2008, 10:26
