what's the best media format that combines quality and size? I usually use .wmv to store files on my cpu and save space. Is there anything better than that? Does anyone recommend any others? avi? I save clips every so often and they end up taking space up that I could compact into a lesser format (for the highher quality clips). Any sugestions
Thread: Best format for quality & size?
Look into XVID.
would that save space??? that's my main concern
XviD is a codec, wmv is a container. You want a low over head container or a efficient codec? I guess both if size is the primary concern.
.nut is supposed to have the lowest overhead but I don't think it is at all useable at the moment. So I guess that leaves mkv, although I am not sure how the overhead of a AVC mp4 compares to an mkv.
For really low bitrates I would go with AVC either via Nero or x264. RV9EHQ/10 would be another option or VP7.
For audio I would suggest either vorbis or he aac.
burn em to dvd- data, that should save space!!!!!! :P
COOKIEEE!!!
Best I've seen (even if I'm no expert in this) is actually Nero Digital. I was very impressed with the results, encoding from a DVD.
/Mats
It seems that wmv is the best as far as size goes.....i have some files that are mpeg's that i'd like to convert to a smaller size file...i don't mind losing a little quality but i don't want it to become pixelated.....what's the best quality wmv? is it dsl 1 mb?
Originally Posted by DonGallego28
your question was answered here
http://www.videohelp.com/forum/viewt...284310#1284310"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Multiple questions on best file format & quality, conversion from AVCHD
By Scanderoon in forum Newbie / General discussionsReplies: 12Last Post: 2nd Sep 2011, 01:37 -
Best Video Format/Codec For Small Size, Yet Low Loss In Quality?
By kiwisoup in forum Video ConversionReplies: 13Last Post: 27th Jul 2010, 10:01 -
Whats the best format for good video quality with reasonable file size
By hasanali00 in forum ffmpegX general discussionReplies: 2Last Post: 20th Feb 2010, 21:29 -
.avi to .VOB format - without changing size & quolity
By akakiami in forum Video ConversionReplies: 5Last Post: 19th Dec 2009, 11:48 -
VOB & MPEG4 HD to Windows Media Compatable Format (DVD Quality?)
By RobsterNo1 in forum Video ConversionReplies: 2Last Post: 28th Oct 2008, 06:49
