VideoHelp.com Forum
  1. Was wondering if i could get some info on what the deal is with clv. I have a verbatim 8X dvd+r (mc MCC 003) and one that is a verbatim 16X (MCC 004). When put the 8x in my liteon 812 drive and go to DVDinfo it says it will burn at 2.4, 4, 6, and 8. When i put in the 16x i only get a clv of 2.4 which sucks. Is there any way to change this speed or i saw an omnipatch tweak to change dvd speeds but didn't want to change anything till i got some input.
    thanks
    tlrbjc
    What firmware are you using for the 812S?
  3. USOQ as far as i know this is the latest.
    this is what i get for the 16X.
    Region information N/A not a DVD-VIDEO
    Media code/Manufacturer ID MCC 004
    Media Product Revision Number 00h
    Format Capacity Blank Disc
    Free Blocks 405405696
    Free Capacity 4.38GB(4.70GB)
    Book Type DVD+R
    Media Type DVD+R
    Manufacturer Rated Speed 16.0x 22160KBp
    Available Write Descriptor CLV 2.4x 3324KBps
    Data area starting sector 30000h
    Linear Density 0.267um/bit
    Track Density 0.74um/track
    Number of Layers 1
    Complete Media Code
    00000000 08 02 00 00 A1 0F 02 00 00 03 00 00 00 26 05 3F .............&.?
    00000010 00 00 00 00 00 00 07 4D 43 43 00 00 00 00 00 30 .......MCC.....0
    00000020 30 34 00 38 23 54 37 12 02 54 6C 02 92 5F 15 15 04.8#T7..Tl.._..
    00000030 0B 0B 08 08 01 19 1B 0C 0C 0C 0D 01 00 00 00 00 ................
    and this for the 8x
    Media code/Manufacturer ID MCC 003
    Book Type DVD+R
    Media Type DVD+R
    Manufacturer Rated Speed 8.0x 11080KBps
    Available Write Descriptor CLV 8.0x 11080KBps
    Available Write Descriptor CLV 6.0x 8310KBps
    Available Write Descriptor CLV 4.0x 5540KBps
    Number of Layers 1
    Complete Media Code
    00000010 00 00 00 00 00 00 03 4D 43 43 00 00 00 00 00 30 .......MCC.....0
    00000020 30 33 00 38 23 54 37 15 02 52 6C 02 B4 63 15 15 03.8#T7..Rl..c..
    00000030 0B 0A 08 08 01 19 1B 0C 0C 0C 0D 01 00 00 00 00 ................
    u can see the Clv difference. Weird a slower burn for a faster speed!
    Lite-On hasn't added an 8x write descriptor for MCC004, and isn't likely to, for the 812S. You'll have to use one of the patched 832S firmwares. I have an 812S, but am using 832S firmware VS0G, and when I put in an MCC004 disc I get 2.4x-8x speeds available.
  5. gen-an, first off thanks for the help. Actually you answered a question i have been having about the firmware. I thought by using the 812 firmware that this would give me "dual layer" capabilities. I didn't know i could use the 832's firmware. Guess this is the one to make my dvd dual compatible. Thanks going to upgrade to that right now.
    thanks again
    tlrbjc
  1. O for 5 Verbatim
    By pepegot1 in forum Media
    Last Post: 16th Sep 2011, 11:58
  2. Verbatim from Fry's
    By swkenney in forum Media
    Last Post: 1st Nov 2010, 09:02
  3. Verbatim Sale
    By PhoneMatt in forum Media
    Last Post: 27th Feb 2010, 19:51
  4. Verbatim Dics?
    Last Post: 7th Dec 2009, 04:43
  5. Verbatim CD
    By mis3 in forum DVD & Blu-ray Writers
    Last Post: 26th Jul 2007, 00:11
