Does anyone know for sure if the LVW-5045/5005 sold in the USA will record from a PAL source besides NTSC ???? I know the Tuner is NTSC only, but I am not sure about the composite connectors if they can accept video from a PAL source ?????
I called today Liteon about this issue but unfornately they couldn't give me an answer!!! I looked at so many other sites on the Internet and got conflicting info. For example, when you look at LVW-5045 on newegg.com it would say that this unit has SCART connectors. However, when you look at the pictures they provide for that unit, it shows only US connectors like S-video and composites and components. SCART connectors are more common in Europe. Therefore, if you see a SCART connector on any DVD recorder then you would know for sure that it can record from PAL video source. Otherwise, you have to guess or ask around as to whether it will record from PAL source!!!
My understanding of the unit is that if you change the unit to PAL mode it will record in PAL because mine supposely has a chipset modifcation. Now the problem is that I only have a NTSC tv so I wont be able to test it. I am waiting for a DVD my cousin is making from Australia to see if it will play back on my unit as it was spec'ed to do.
Based on my old reading from some users answer should be yes. This recorder should record in PAL from PAL source.Originally Posted by tim1984
For more recorders look here http://www.videohelp.com/forum/viewtopic.php?t=175481Pinnacle Studio 8 and DV home video editing (ver.9 already home)
Upgrade Liteon lvw-5045 to 400G successfully
By totoro168 in forum DVD & Blu-ray RecordersReplies: 182Last Post: 6th Mar 2011, 20:06 -
LITEON LVW-5045 cannot read DVD-R disks
By elfie-gow in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Jan 2011, 16:58 -
Liteon LVW-5005 can’t prepare 16 X DVD-R before recording
By coody in forum DVD & Blu-ray RecordersReplies: 24Last Post: 8th Jun 2009, 14:54 -
LiteOn LVW-5005 timer recording fails?
By bevills1 in forum DVD & Blu-ray RecordersReplies: 15Last Post: 13th Jun 2008, 09:37 -
LiteOn Lvw-5045 (UK - English)
By cubud in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th Jun 2007, 14:05
Statistics
Newest guides
Latest tool updates
New media comments
