VideoHelp.com Forum
Page 1 of 32
1 2 3 11 ... LastLast
Results 1 to 30 of 954
Thread: The Best CIS ?
  1. Member bidefordboy's Avatar
    Now that there are quite a few different cis systems available I thought it would be a good idea to start a new thread for cis systems in general.
    I have previously owned the JWLSales system, but after having problems with the carts decided to dump it & try a new system.
    The system I have ordered now is available here :- http://cgi.ebay.com/ws/eBayISAPI.dll...760875806&rd=1
    Will keep you all updated on my progress with this system.
    Would be good to get a general overview of the different systems posted by users. We could all help each other out with problems & fixes.
    Here are some links that may be helpfull:-
    http://www.printonadime.com
    http://www.printforless.tk
    http://nomorecarts.com
    http://marrutt.com/lyson-contin.php
    http://search.ebay.com/continuous-in...jsZ1QQfromZR40
    I just got my Jwlsales cis a week or so ago im going to order the printonadime cis (new 100ml tank) macrovision gives it high scores my Jwlsales colors are a little off
    I just ordered a printforless kit with 100ml dual chamber tanks. It was $70 including shipping but doesn't include ink. I'm planning on filling it with the Sam's/Costco stratatec ink. I'll let you know how it goes.
    Glad to be here with you guy's because we know how printer manufacturers make most of their profits( high prices for carts ) and they don't want us using cis because their afraid we'll save money...I'm happy to report progress with my printonadime cis although I bought it in a rush being that my jlwsales cis broke my printer from constant leaking and I didn't trust repairing it for the millionth time! I bought the printonadime combo(printer with cis kit)for $199.00...I make my money with the printer so I needed it yesterday at that time...If I could have waited I would have bought the 100ml cis but I was in a rush however I use it all the time and it doesn't use massive amounts of ink and I use an entire syringe(with needle) during refilling and it's no longer a painful process(with the needle) And don't forget to print a nozzle check every two or three days...you don't need the computer...(R200)just hold down the paper button and press the power button while holding down the paper button...release the power button while still holding down the paper button...when the power light starts to flash release the paper button...after start up is finished it will print a nozzle check...make sure paper is loaded...DUHH!
    Is what we learn indeed a fact, or someones opinon?
  5. Member bidefordboy's Avatar
    Have received a email from 'toppyjess' to say that my system has been dispatched, so hopefully will be able to report any prob's with installation & operation in a few day's.
    I think the first thing I will do is setup the auto print programme that I downloaded from the printonadime site. Will set it up to print out a purge test each day when I know my pc will be on. This may seem like overkill, but after the prob's I had with the JWLSales cart's, I would rather be safe than sorry.
    Can't wait for you to get yours going bidefordboy...I want result dammit....progress for all..and by the way...HIP HIP HORRAY!! FOR BIDEFORDBOY Thanks for bringing us to a new forum rather than us posting in that sorry a?s JLWSALES forum...we all know that JLWSALES cis kits suck!!!!!
    I HATE ALL OF YOU! HATE, HATE, HATE!
    I bought the "jump-high, run far", wonderful, fantastic JWL CIS kit that EVERYONE was raving about on here. Haven't even hooked it up yet (had it a couple of months now) and already I'm afraid to do it. All I read now is that it's nothing but junk. GEESH! Fellas (and ladies), make up your minds, I can't afford to keep up with the Joneses.
    Guess I will buy one from Toppy-Jess and see if it works.
  8. Member bidefordboy's Avatar
    Don't be disheartened Captain315, your system may work fine. When I first got my JWLSales kit I thought it was the best thing since sliced bread. It worked really well for a few months. But it's like car's, we might both have the same model but I get load's of problem's & you get none. Sometime's you can blame it on the driver. Your cart's may be improved one's. You might as well set it up & get your money's worth.
    I think that's what I will do. Am going to get rid of the Canon S-900 and I-950 printers and replace them with the Epson R200's. I personally will NEVER buy another Canon product. These have been nothing but trouble since the day I got them. On the other hand, I've not had one minutes problem with the R200. I just hope the JWL kit doesn't screw it up. LOL
    Advice please..... Is there any advantage to getting the pigment ink rather than the dye? I read on the Toppy-Jess ad that the pigment ink is "water-resistant". Have any of you ever used the pigment ink that can give us your evaluation as compared to the water-based dye ink? I'd like to not have to spray my discs if at all possible.
    Thanks!
  11. Until we see some long term use like with the JWL system, its hard to tell if the Printonadime will truely be any better.
    I always say that I'm lucky that I'm a technician...I'm not gonna get rude but the truth is the truth...if you don't believe me for those of you whom already replaced your jlwsales kit take it outside and break one of the carts open and post your findings....not only are they hollow ( the reason why it uses a sh**load of ink ) but also the outlet port is a cheap piece of rubber when it's suppose to be a valve (the reason why it cloggs and leaks).....as I posted before..I've taken the OEM (EPSON ) carts apart and it has chambers (causes the ink to spray when charged up by the printer) and the outlet port is a valve (keeps an air-tight seal) but as usual "Experience is the best teacher"...the only thing that the new CIS kits (Printonadime,ECT.)are missing is that the OEM carts have a built in filter! I will soon post pictures of the insides of the different carts...but anyway get your moneys worth from your jlwsales kits and when it gives out replace it with a CIS that's been tested by the good people of this forum...Don't hate us because we're trying to help people not make the mistake we made with jlwsales...are you going to go to china and sue jlwsales if his kit f**ks up and he refuses to replace it.....your better off with something guaranteed by city,state, and federal laws this way you can get what you paid for with piece of mind...printonadime has a 30 day policy...just something to consider...GOOD LUCK!!!
    as for pigment ink...I'm gonna contact Epson and ask about pigment ink and DVD printing...I'll post the results tommorrow because their closed right now.
  14. I bought mine from this company http://www.think4inc.com/cgi-bin/webdatapro/t4idb.pl. I paid $99 for it during a local computer show. The chips reset automatically and it never runs the self cleaning mode. I have to run it myself. It runs better now than it did with the original MFG carts.
    I have not taken the carts apart so I don't know if they are hollow or sponged. I do know they have worked for me for atleast 3 months. I have let my printer sit for a week or so without printing and then printed without problems.
    I have purchased fefill inks from costco for this unit but I will not need them for a while yet. I have printed over 300 DVDs with this setup plus over 150 DVD inlets not to mention just misc. printing. The only thing I did different with my setup is the stickies to hold the tubes I replaced with velcro, so I can pop the system on and off in seconds if need be. I will probably add the cleaning bottle soon, but I don't have to clean my heads very often. Matter of fact I think I have only done it 2-3 times total.
    Thanks macro.... Myself, along with many others would like to know the true lowdown on pigment ink. BTW, I hope your realize that I was just joking about the "hate" stuff. This is all a trial and error learning process.
  16. Member bidefordboy's Avatar
    @ dun4cheap
    Obviously a respectable company, if they have taken the same care in selecting a cis to stock as they have with their website you should'nt have any problems.
    Have you guy's seen the video's available at the printonadime site ?, very informative.
  17. Originally Posted by macrovision
    Yes it would seem the design alone makes it a better system. If I was buying right now I would go with the printonadime system. I actually plan on getting a new system to replace my old JLW. I was one of the first users to get the JLW system. I know what you mean about the problems. I've had to resurrect this thing soooo many times. Hopefully the printonadime will prove to be a dependable system.
  18. I find it interesting that with the printonadime link you cannot add the CIS system to the cart. Whats with that?
  19. I knew too many people has using JWl CIS and only a few had problems cause of defected parts. I've ran JWL CIS since day one and had NO problem at all, checked wasting ink (on back pannel) is fine. Just want to let people already purchased JWL system and no chance to hook it up then go ahead and do it, not too many problem like some guys mention. Try it and you will know, and if you got the defected parts just email JWL, he will send you a new one.
    obviously Locky you haven't seen the technical differences in the jlwsales cis versus other cis manufactureres....the jlwsales cis cartridges are created so cheap that I would rather use my previous jlwsales kit to hold colored sand and maybe it would still fail...look at the outlet port on the jlwsales kit and look at the epson carts outlet port...What's the difference? answer that yourself because I know the difference that's why I'll never put it in my new printer...not even for the love of God!!!! I replaced a cart with one he sent me...he sent no instructions and I had to E-Mail him about 20 times and wait for 2 weeks....I had to buy OEM carts until I recieved the replacement part which happened to be a better cart than the carts on the system...It looked just like an OEM cart made for CIS purposes...why don't he use them in the manufacturing of his kit?...Because their more expensive????anyway If yours fail maybe you'll take a trip to china to get your money back...I'm not upset with your comment because to each his own...I learned my lesson the hard way...maybe you'll have a good teacher(Experience)
    How many people in here never failed science class?
    How many took the R200 and successfully put it back together??? How many use common sense to get through problems???? Use common sense and don't get had....I got had and now I know better!!!
  22. Hey guys, I have some great news!
    *I saved money on my insurance..... and on the ink carts that I have not had to buy!!!
  23. Member
    I just ordered the printonadime new 100 ml cis he said hes shipping it tommorrow. i going to make lost of covers and dvd with the jlw sales cis to use all the ink. When i first installed the jlwsales kit i couldnt get the patterns without blocks in the clean head maintenance. Now that ive printed alot so far i get a clean test pattern. The color is off a little but it still looks real good on the epson glossy photo paper. My cis (jlwsale ) is new but im not taking a chance. Thats why i ordered the printonadime one. plus the guy from printonadime has always answered all my question (and there were lots). good product along with someone who cares ie customer service goes along way
  24. Member
    Ultraman, I know what you mean and will always listen to advice given to me from someone who doesn't have a hidden motive behind the advice for instance a person that works for jlwsales will do everything in their power to get you to buy their cis kit but this forum is made up of people that have nothing to gain from our advice...I will tell all...even if it's bad about whatever company I deal with and I don't care if others take offense unless the others are gonna pay me to keep quiet(make me rich)and if people wanna go with jlwsales....GODSPEED!!!!As for me...I got what I want(A good CIS that doesn't F**K my printer!!! )THANKS!!
  25. Member
    Lol i was printing dvds and i heard a screech and the tubing got caught under the cartridge holder luckily the tubing didnt get split open weww
  26. Macrovision,
    Look like you work for PrintonDime ? so far read all posts, you the only one who says bad about JWL system because your first impression (JWL sent you the bad one). Yes you are a technician and all other just the operators ? don't bring your personal issues to confuse people.
  27. Member habs01's Avatar
    Macrovision, your bashing JLWSales kit and hyping Printonadime seems a little excessive at this point. Saying stuff like the JLWSales will destroy your printer is exageration. I know that as of lately quite a few people have had problems with the JLWSales kit and these problems are stated in the JLWSales forum; which is fine.
    I installed my JLWSales system 3 months ago. I use it pretty much on a daily base and have had zero problems so far. What I'm getting at, is that while other CIS kits may be technologically superior, this kit works fine for me and probably for a bunch of other people who bought it. It seemed like the best bang for buck CIS kit at the time. Is it still now? Maybe not. Alot of other kits are available now. Some new kits may be better. But then again, just as what happenned with the JLWSales kit, problems might develop over time, maybe different problems who knows?
    I think alot of people come here looking for help, reviews of CIS kits and unbiased information to help them make decisions.
    Just my 2 cents.
    Fast, Cheap, Good: Choose any two.
  28. Member
    We'll just for your info. I want you to know that I recommended other cis kits not only printonadime cis...quite frankly I don't care if you use jlwsales and yes it leaked in my printer causing the gears attached to the waste pad to go out of sync. causing constant error messages...I dealt with it as best as I can...maybe you don't and won't have problems but theirs always experience as I've posted...I hope you don't have problesms but I will tell you that if you do you should remember the only point I stressed was that the outlet port onb the jlwsales kit is built wrong...it's a peice of rubber and this is the problem....the only problem...I'm gonna mod my jlwsales kit with carts form another cis manufacturer because I like the tanks on the jlwsales....every complaint was about the carts,not the tanks but if you get off on combative tactics be my guess...my system is what I wish I had bought from day one and my other printer is being repaired under warranty so I only lost what I'll spend to make my jlwsales cis OEM standard!!! If you have problems with yours maybe you'll see I'm not bashing jlwsales I'm informing others to beware of the cart construction and as for me being a tech....F**K fixing....surface mount technology makes equipment too expensive to repair so we test daughter boards and the ones that's bad we replace with new ones and sell the defective ones to companies that refurbish them or recycle them...fixing is so 1990's
  29. Member bidefordboy's Avatar
    Well my 'ToppyJess' kit arrived on Wednesday, three day's from Hong Kong, very good, could teach our postal service a thing or two.
    It arrived in the usual speed post green bag. Inside the kit was packed in a plain white box with T481-T486 printed in the top left hand corner. The box was wrapped in a couple of layers of bubble wrap, and the contents were also bubble wrapped so the packing was ok.
    The ink tanks are about the same width as the JWLSales one's but slightly taller. they are full to the brim & the cart's are also full, so no need for priming.
    I had to remove the cart cover from my printer (r300) because of the placement of the tubing clip that is near the back of the cyan cart, or the cover would not be able to close.
    Removed the rubber plugs from the tanks & replaced them with the filters supplied.
    Plugged the carts in & routed the tubing roughly to where I thought it would end up & stuck it down temporarily with insulating tape.
    Started the printer up & it went through the usual process of charging the carts. When it was finished I tried a nozzle check. Ther were a few broken lines, so I did what was recommended in the instructios & ran the cleaning cycle a couple of times. Did another nozzle check, much better but still not perfect. Then printed a purge test & then another nozzle check. Pefect.
    So now time to route the tubes properly. Owners of the printonadime system will now how the brackets are fixed on their r200's, well because I have the r300 I wanted to have the tubing coming out of thr printer on the left hand side, so that the trap door for the card slots could be opened easily. The brackets are in the same position & the tubing is fed through from the carts but then over the top of the tubing clip & back to the left, there is plenty of flexibillity in the tubing so It won't harm it.
    Then the straight bracket was pushed all the way through the bracket that is attached to the printer housing, and I attached the tubing the the end slots. Then stuck the tubing to the left hand side of the printer with some more insulating tape.
    One good thing about this kit is that it gives you about 10" more tubing than the JLWSales kit, which makes things a lot easier.
    On the r300 the top cover closes flush to the body of the printer & obviously if you did'nt do anything about it it would damage the tubing if you pushed it too hard. So instead of putting the tubing through the small clip that is supposed to attach it to the body of the printer, to protect it when you close the cover (which would'nt work on the r300), I have left the tubing attached to the printer on the left side with insulating tape, & have assembled the small clip & stuck it on the ledge just above the tubing where the cover closes, this is just enough to stop the cover from damaging the tubing.
    Hope this all makes sence so far, have had a busy day but wanted to post it before going to bed.
    The quality of the ink is great, I cannot see any difference in the prints with this system & the one's I did with the JWLSales system. Nice bright colours & dense blacks. Also the tubing does'nt stink & the only time you can smell the ink is if you put a fresh print close to your nose.
    Well as you can see, I am very happy so far, let's see if it last's.
    Now I am waiting to see if the chips reset to 90% when the monitor gets below 10%, and also if it performs a cleaning cycle. Will keep you updated.
    Here is the system again, to refresh your memory
    http://cgi.ebay.com/ws/eBayISAPI.dll...761504155&rd=1
    My system is prefilled but they also sell empty systems so you can use your favourite ink, the syringes are used for refilling the tanks.
  30. Member
    Hey bidefordboy...I seem to have a couple of haters in this forum...they call theirselves bashing me for giving advice about the jlwsales carts...I think that they have fears that thier kit might go caput oneday because of my postings???? I'm not a witch...I'm not a witch!!! If you get along fine with jlwsales..I'm happy for you...If your carts start leaking and you get alot of greif...modd the damn thing..you don't gotta buy another cis...use the OEM Epson carts(Mod them ) That's what I'm gonna do with my previous jlwsales cis but in the mean time I bought another cis...you don't have to buy printonadime,toppy-jess,printforless...remember I gave the links from E-Bay..I don't care if you pour the ink into the printhead straight from the bottle...It's your printer...not mine..and it's your hard earned money...not mines...I was trying to help those that can't afford two or three cis kits until they find one that meets OEM standards and If you read correctly I posted that the only thing wrong with the jlwsales cis is that the OUTLET PORT IS BUILT WITH A RUBBER STOPPER INSTEAD OF A VALVE...THAT'S WHY IT LEAKS!!!!!!!!!!!!!!! When he sent me the replacement cart it was OEM standard...I wish he had sent me all six but instead I might try to buy all six from him..I posted thast he should BUILD THE CIS WITH THOSE CARTS..but anyway as I always say " EXPERIENCE IS THE BEST TEACHER" I just want people to make a good choice... every person that comes to this forum may not be able to spend $100 and not care if it's the best choice. If I could do it again I'd buy a different CIS but on the bright side I learned alot about CIS kits and I learned how to build my own but I need my broken jlwsales cis for the tanks as for my recommendation for the best cis kit out there...Talk to LOCKY AND HABS01
  1. Replies: 10
    Last Post: 10th Nov 2009, 16:49
  2. Looking for a CIS(Continuous Ink System)for an Epson RX580
    By Jake802 in forum Newbie / General discussions
    Last Post: 19th Jan 2009, 01:02
  3. printer suggestions n CIS
    By rojen in forum Linux
    Last Post: 14th Jun 2008, 07:30
  4. CIS for Epson R260
    By Devon05 in forum Media
    Last Post: 1st Mar 2008, 01:17
  5. Replies: 0
    Last Post: 16th Jan 2008, 14:41
