ok i want to roll back to me cause im having to many problems with service pack 2 if i do this will i lose any files that were downloaded with xp
thanks in advance
Results 1 to 11 of 11
Thread: rolling back from xp pro to me
one problem solved can solve alot of problems
It should be easier to rollback SP2 than install ME. You might have to reformat your hard drive, especially if is formatted with NTFS under XP to Fat32 under ME. If THAT is the case, then all your files on the C:\ drive go bye bye.
I agree with Soopafresh. Just rollback SP2.
Roll back? Maybe that's your problem. How did you upgrade? Xp over ME? or Fresh install?
If you went XP over ME and also went NTFS then I doubt there would be any going back to ME and it's Fat32. If you kept the fat32 intact then perhaps that is leading to some of your problems.
Maybe we can sort out your problems with SP2 and then you won't have to "roll back" to Windows ME. Going back to ME from XP Sp2 is sort of like getting your balls caught in a bear trap. Not much fun for you. Too many people complain about issues with SP2 and don't realize that they could fix everything with a few driver updates.
Yeah Windows ME is really not a good OS. What problem are you having with SP2?
Also the question about how you installed XP (ME Upgrade or Fresh install) is VERY valid.
Uninstall XPSP2, and rerun the XPSP1 install over top, then turn off automatic updating, windows time, and about 30 other useless services.
Cheers, Jim
My DVDLab Guides
ok update time i had to unfortunally reformat my computer,i lost some files but saved most,now when i restall my home edition all i get is warnings about registery problems.ive all ready reformatted my pc 2 times to day done a fdisk redone that and its still happening,is there a bug in my harddrive or is there a cure to this problem please help
You need to be more specific. What are the registry errors ? Describe the procedure you did to install Windows. Did you reinstall XP, or install ME ?
hmmm..registry problems on an install AFTER format??
If drive is partitioned you formated all? how'd you re-do fdisk?
Turn off anti-virus in the BIOS.
Set BIOS to "Non-PNP OS Installed".
Disable com 2 if you're not using it.
Set primary display to whatever type of card you're using.
Use the hard drive manufacturer's utilities to wipe the drive (write 0's to it), then boot to the XP CD and install.Cheers, Jim
My DVDLab Guides
What does it mean if Sony Vegas Pro is a full back up?
By Khead161 in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2012, 21:02 -
Burned DVD plays back with rolling / flipping screen
By thedaylights in forum Authoring (DVD)Replies: 3Last Post: 4th Nov 2009, 14:14 -
rolling/jumping with VHSc
By highaim in forum Newbie / General discussionsReplies: 2Last Post: 25th Jul 2009, 21:03 -
Semi-Pro DVD back-up issues
By xoADAMox in forum Newbie / General discussionsReplies: 4Last Post: 6th Jun 2008, 08:15 -
Play back jumpy in Premiere Pro 2.0
By cobra jet in forum Newbie / General discussionsReplies: 8Last Post: 28th Jan 2008, 10:42
