VideoHelp.com Forum
Results 1 to 11 of 11
  1. Was wondering if you can make DVD copies using a burned DVD copy? Will you lose any quality? If so what program?
  2. Wow....
    dvd decrypter. ISO read->ISO write
  3. VH Veteran jimmalenko's Avatar
    I'm with steve ....
    if it's burned, then the only issue you might have is if it's on a DL DVD and you want it on a SL DVD, which is where DVDShrink comes in. If not, DVDDecrypter's ISO Read / ISO Write combination is the way to go IMO.
    If in doubt, Google it.
  4. Member Shocker Milwaukee's Avatar
    Yes. Exactly 2.3% quality loss with each generation.
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  5. VH Veteran jimmalenko's Avatar
    Is that before or after tax ?
  6. Member Shocker Milwaukee's Avatar
    Don't make me get out my slide rule to show you the calculation.
    George Carlin
  7. Originally Posted by Shocker Milwaukee
    Are you serious about this? There is a quality loss. How do you know its 2.3% and why is there any quality loss at all?
  8. Member garryheather's Avatar
    No, he's not serious.
    Unless it's a -R burnt right to the rim in which case it won't fit on a +R (a really small size discrepancy between the two which most people never notice), you can just copy one disc to another unless the original backup - now there's an oxymoron - is a dual layer and you're trying to put it on a single.
  9. It depends upon what you're talking about in making a copy of the backup. When we would make a VHS (of 8mm, Hi8, beta or any analog) copy, there would be a noticable generation loss with each copy. When you are dealing with digital media, then you do not have such a generational degradation. The copy is the same as the original. If you are talking about processing the data in some manner, such as compressing, then there will be a loss of quality in the processing. But doing a copy without any type of processing will be the same as the original (assuming that there are no minor read/write errors).
  10. I agree with Cinemagic.
    NEC ND3500A/G
    Unproper and proud of it
  11. Thanks for the help guys.
  1. Replies: 214
    Last Post: 11th Jan 2012, 12:42
  2. Making DVDs from backups of VOB files
    By kirklt in forum Authoring (DVD)
    Last Post: 26th Aug 2009, 08:52
  3. Replies: 4
    Last Post: 27th Dec 2008, 13:50
  4. Looking for best way to compress dvd backups
    By Wolfsrudel in forum Video Conversion
    Last Post: 2nd Jan 2008, 13:36
  5. The Importance of Backups
    By Soopafresh in forum Computer
    Last Post: 9th Sep 2007, 17:31
