VideoHelp.com Forum
    What really attracted me to SVCD2DVD was it's menus (ie you could capture a bmp from the movie and use it for a menu & you could use an audio track in the menu).
    I have registered RC8, however, I have found a problem with it's menus.
    If I burn a DVD created by SVCD2DVD without any menu, then the DVD plays OK on my DSE G 1607 player, and on the computer using POWERDVD software.
    If I burn a DVD created by SVCD2DVD with a menu, then either the DVD doesn't detect on my DSE G 1607 player or, if it does detect, it plays the menu with about 10 seconds of it's audio and will not go any further (ie it will not play any of the main movie), but on the computer using POWERDVD software, there is no problem and the whole DVD plays OK.
    Does anyone know how to fix this problem?
    Thanks,
    Gerald
  2. Member ChrissyBoy's Avatar
    Does your DSE G 1607 play both NTSC and PAL DVDs? Have you tried the different menu audio encoding options? Silence AC3, Silence MPA, Custom AC3 & Custom MPA?
    Yes my player plays PAL & NTSC DVDs and I'll try theother options
    At last, I've tried all the options and found the solution, but it's a solution, I do not like.
    If I record any DVD with a menu with audio, the DVD can not be played, if I dont include any audio, it plays OK.
    If I include audio, then then format of the audio does not matter.
    This is an annoying restriction, but not terrible,especially as everything works on the computer, it's just the standalone player that can not have menus with audio.
  1. trouble with SVCD2DVD menu selection highlighting
    By bobarnett in forum SVCD2DVD & VOB2MPG
    Last Post: 4th Sep 2011, 14:59
  2. SVCD2DVD Error when encoding menu??
    By gsmb in forum SVCD2DVD & VOB2MPG
    Last Post: 23rd Feb 2011, 13:44
  3. registration problem SVCD2DVD
    By stgreene in forum SVCD2DVD & VOB2MPG
    Last Post: 8th Nov 2009, 00:32
  4. Really strange SVCD2DVD menu problem
    By denali in forum SVCD2DVD & VOB2MPG
    Last Post: 4th Oct 2009, 11:41
  5. svcd2dvd problem
    By dvds2u in forum Newbie / General discussions
    Last Post: 27th Mar 2008, 11:05
