VideoHelp.com Forum
    I have a project for school, and i have to make a video and my plan is to use Chroma Key for the video. what i am going to do, take an image or footage of a monopoly board, and i was wondering if i could shrink 2 individuals to act as the playing pieces of the game. I understand most of the project, the only thing i really don't understand is how can the individuals walk on the board if the Chroma Key is a board standing vertical behind the characters :S well any help would really be appreciated thanks in advance.
    An all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> http://www.dvdrhelp.com/forum/userguides/167502.php
  2. Member dipstick's Avatar
    You may want to try having the actor standing on a large blue or green tarp and shoot them from overhead. Maybe from atop of a tall step ladder or whatever. Then simply key in the color of the tarp and resize down the footage to overlay over the board image.
    like at school we have the green board, but its just staning verticle, like so that you can stand in front of it, but i don't think they would alow us to stand on top of the green board, i mean they are expensive. The teacher did tell me something about shooting the video in a similar angle you were telling me, so if you can further elaborate, cause i need a bit more understanding please. thanks
  4. Member aanaravs's Avatar
    You definitely need to shoot vertical, such that your actor is walking on a green screen. If you are worried about using expensive equipment, go to one of the art stores and purchase green table cloth. I recently purchased a 100' roll for $7.
  5. Member dipstick's Avatar
    A green board would be ideal but not nesicery. You can use a simple Green Plastic or canvas tarp on the floor. You can get the tarp cheap at any local department store. You can key in the color in Premiere to set it transparent. You'll have to play with the settings until you get the results you want.
    Hey thanks guys, yeah i downloaded this image where it had a green screen, and well all i had to do is just mess around with a color palette in Adobe Premiere Pro 7.0 So i can buy a green cloth, and just put it on the floor, and it would be like the monopoly board being the huge cloth right, depending on the angle of the camera. Now should the shot of the camera be completely overhead, or should it be at an angle? thanks in advance guys
  7. You can also mask off parts of the frame nearer the camera, using pieces of green or blue card (the same colour as your main background). You need to light the card to the same brightness as the main scene. This saves you having to cover a huge area of your 'studio' when the actors are just standing still in the centre of frame.
    In Sony Vegas (if you can get hokd of a copy of that) you can set a coloured 'cookie' that does the same thing.
    After experimenting for a while, i found out that Chroma Key can also use different color back grounds other than blue and green. I was just experimenting, and i used a red back ground and got just as good results. all you have to do is set up the transparency on the red color.
  1. Complex chroma key matting problem
    By Morality124 in forum Editing
    Last Post: 7th Nov 2010, 15:36
  2. Can Premiere CS4 do quality chroma key? I can't
    By MAtkins in forum Newbie / General discussions
    Last Post: 26th Mar 2010, 02:49
  3. My first attempt at a bluescreen chroma key
    By CogoSWSDS in forum Editing
    Last Post: 16th Apr 2009, 22:11
  4. Vegas adding video overlays using chroma key
    By SearchQuality in forum Editing
    Last Post: 14th Dec 2007, 17:12
  5. An alternative to the Chroma Key.
    By fr4nk in forum Editing
    Last Post: 8th Jun 2007, 13:45
