I have a movie that I want cut scenes out of and I am using Nandub. Most of the time I have no problems except with some movies (as is the case with this particular one) I receive the above message when opening the file and after editing and trying to save the edited avi I get an error saying the following
"The source video stream uses a compression algorithm which is not compatible with AVI files. Direct Stream Copy cannot be used with this video stream."
Help plz.
Bump, anyone?
Hi-
Have you tried VDubMod for the job instead? I have no idea what that message means, assuming you're trying to split up only AVI files.
I've seen this before in VDub, and isn't that just saying that you can't use Direct Stream Copy on this file, so you have to use Full Processing or the Recompress modes ?Originally Posted by DreamTFKIf in doubt, Google it.
Error while drugging MPEG 2 file to virtualdub
By eliqush in forum EditingReplies: 8Last Post: 4th Nov 2009, 08:53 -
parsing an avi file
By pi-1966 in forum ProgrammingReplies: 0Last Post: 27th Apr 2009, 05:08 -
DVD authoring fails - 'error in parsing XML'.
By Levina in forum ffmpegX general discussionReplies: 12Last Post: 22nd Mar 2008, 09:10 -
Parsing error
By screenhoofd in forum ffmpegX general discussionReplies: 6Last Post: 6th Oct 2007, 07:17 -
Non-interleaved?
By KingBongo in forum ffmpegX general discussionReplies: 0Last Post: 11th Jun 2007, 06:47
