I'm converting 26 VOBs to MP4s for an open source project (using MPEG4 [.MP4] (ffmpeg) codec). All the VOBs converted except for two. When I hit Encode on these files, the Progress window comes up and it finishes the encoding instantly (the originals are +- 465MB files). The window reports Finished (not Failed). The output file is a Zero KB file.
This is strange as I am using the same preset for all the files, and the others work fine.
The two VOBs in question don't seem any different than the others - they play fine in MPlayer.
Here's what the Info button on the progress window gives:
Encoding started on Tue Mar 29 14:48:09 SAST 2005
Input #0, mpeg, from '/Users/admin/Documents/go_open/Episodes/Episode2/VIDEO_TS/VTS_01_2.VOB':
Duration: 00:07:28.7, start: 987.495000, bitrate: 8693 kb/s
Stream #0.0: Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
Stream #0.1: Video: mpeg2video, 720x576, 25.00 fps
Codec type mismatch for mapping #0.0 -> #0.0
I tried (as an experiment) other codecs on these two VOBs. Xvid [.AVI] (mencoder) succesfully encoded the VOB. Where as Xvid [.AVI] (ffmpeg) results in the problem behaviour. It seems that any "(ffmpeg)" labelled codec produce the unsuccesful results described above.
The only related topic I can find in the forum is:
Stopped working all of sudden (VOB to .MOV)
http://www.videohelp.com/forum/viewtopic.php?t=262615
I would much appreciate help with this problem. Thanks!
I believe your problem is simply the inverted streams. Try turning ON "Invert Mapping" in the audio tab after having selected your preferred preset and settings.
Inverted meaning, most often the video is in #0.0 so FFMPEGx is trying to treat the audio as video and it fails.
Stream #0.0: Audio
Stream #0.1: Video
Cheers,
Alph
ripbot264 not working properly with Windows 7 x64 - finishes in 1 sec ???
By xlr8r18 in forum Blu-ray RippingReplies: 14Last Post: 8th Jul 2011, 19:04 -
Repeating last frame until audio finishes - Premiere Pro
By LAM_ in forum EditingReplies: 3Last Post: 20th Apr 2011, 06:57 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Conversion finishes in a seocond !!!
By shori in forum ffmpegX general discussionReplies: 19Last Post: 17th Mar 2008, 08:53 -
VOB to DV last VOB file finishes in about one second w/no data
By Gizmology in forum Newbie / General discussionsReplies: 3Last Post: 31st Jan 2008, 17:39
Statistics
Newest guides
Latest tool updates
New media comments
