See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: The parameter is incorrect.
at QuartzTypeLib.FilgraphManagerClass.set_CurrentPosi tion(Double pllTime)
at x3284ccece41ee22b.x79ed6fa5f8db6479.x989d8036a6d61 186(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at DevComponents.DotNetBar.BaseItem.RaiseClick()
at DevComponents.DotNetBar.BaseItem.InternalMouseUp(M ouseEventArgs objArg)
at DevComponents.DotNetBar.PopupItem.InternalMouseUp( MouseEventArgs objArg)
at DevComponents.DotNetBar.ButtonItem.InternalMouseUp (MouseEventArgs objArg)
at DevComponents.DotNetBar.GenericItemContainer.Inter nalMouseUp(MouseEventArgs objArg)
at DevComponents.DotNetBar.Bar.OnMouseUp(MouseEventAr gs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevComponents.DotNetBar.Bar.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
SVCD2DVD
Assembly Version: 2.0.1906.26107
Win32 Version: 2.0.1906.26107
CodeBase: file:///D:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/SVCD2DVD.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Assembly Version: 4.7.0.0
Win32 Version: 4.7.0.0
CodeBase: file:///D:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/DevComponents.DotNetBar.DLL
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///D:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/AxInterop.CodeLock.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
Accessibility
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
Interop.CodeLock
CodeBase: file:///D:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/Interop.CodeLock.DLL
Interop.QuartzTypeLib
CodeBase: file:///D:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/Interop.QuartzTypeLib.DLL
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
Interop.DexterLib
CodeBase: file:///D:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/Interop.DexterLib.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Results 1 to 1 of 1
Thread: jIT dEbugging
Newbie debugging sync audio video problem
By siocnarf in forum Video ConversionReplies: 3Last Post: 24th Apr 2012, 20:42 -
On startup, keep getting a Common Language Runtime Debugging Services alert
By Carl III in forum ComputerReplies: 1Last Post: 18th May 2010, 16:04 -
Debugging coaster problem
By txporter in forum MediaReplies: 21Last Post: 29th Apr 2009, 05:43 -
Need timecode display movie for debugging
By cybertheque in forum CapturingReplies: 6Last Post: 23rd Oct 2008, 16:19 -
ffmpeg works only when debugging
By ariefimansantoso in forum ProgrammingReplies: 0Last Post: 21st Sep 2007, 07:05
