VideoHelp.com Forum
    I've been trying to burn some data-dvds - ordinary files. I wanted to be able to do backups in the same way I used to backup to CD; just making use of the dvd's higher capacity. Because these are data-dvds I can't make use of dvdshrink, dvd-decoder or any of the other 101 programs that exist purely for ripping and burning existing dvds. Instead I've tried to use Nero Ultra 6.6.06; Stomp Recordmax 4.5 and Ashampoo Burning Studio 5.0.3. All these programs give me the same problem which is ..
    The Dvd burns fine and verify's in the program successfully. After that I run Beyond Compare 2.2.7 and perform a crc comparison (or a binary comparison) between the files on the dvd and the files on the harddisk. Half the files are OK - usually about 2GB worth. The rest of the files are unreadable. If I use the "compare with viewer" option then the editor window for the corrupt dvd file shows everything empty beneath the header. If I try to open one of the corrupt dvd files the computer locks up. Using Nero CD-DVDspeed 3.61 and performing a surface scan shows every block green until a certain, apparently random to each disc, point at which time every block after that point is red and gives a crc error.
    Some specifics:
    - My burner is an NEC 3500A, connected as the secondary master running in Ultra DMA2
    - I've used both the 2.C8 firmware (with which I created 10+ semi-coasters) as well as the experimental 2.19 mod firmware (with which I've created one semi-coaster identical to the 2.C8 ones).
    - The computer is a winxp SP2 system with a 3200 mhz AMD cpu, 512 MB ram, a gigabyte 7N400 Pro2 motherboard
    - burns are carried out with no other processes running in the background, immediately after reboot, at x4 or x2 speed - both speeds yield the same result.
    - The media I'm burning to are 4.7 GB DVD-R Infinite disks (code Longten 001).
    I'm pretty sure ppl are going to suggest I change media; although I have to say that surface inspection of the media reveals no scratches and, if it was the media, I would expect the disc not to burn at all or to burn unevenly. As it is every disc burns perfectly until a certain random point at which time everything else doesn't burn after that point. If it was some sort of set limitation I would expect the point of failure to be the same for each disc but it's not. Some discs burn 1.x amount and others 2.x amount.
    I appreciate any ideas as I'm starting to feel I've tried everything by now.
    Change media.
    I have some crappy media that I can burn perfect on, I don't see any scratches but about half the dvd it is still unreadable.
  3. Member Krispy Kritter's Avatar
    Yes...I had a 10 pack of "Longten" media...all were coasters. Tried them in 2 burners, a LiteOn and my NEC3500a.
    Google is your Friend
  1. How to make ovelay semi-transperent ?
    By sharonx in forum Editing
    Last Post: 11th Mar 2012, 14:15
  2. Debugging coaster problem
    By txporter in forum Media
    Last Post: 29th Apr 2009, 05:43
  3. What HW/SW do I need to broadcast a semi pro TV show?
    By sheikvid in forum Newbie / General discussions
    Last Post: 29th Dec 2008, 10:09
  4. Is anybody having trouble burning semi-pro?
    By mikes01 in forum DVD Ripping
    Last Post: 12th Jun 2008, 19:18
