VideoHelp.com Forum
Results 1 to 12 of 12
    Is there program that will strip the music from a file that has conversation in it
    Thank's
  3. You can mess with the filters and equalizer in Goldwave, and possibly get something close.
    If the vocals are on one track, and music on another, it's easy.
    Cheers, Jim
    My DVDLab Guides
    Thanks Jim,
    I have goldwave and just demux with no problem..Let me ask you something, Is there a way to extract the music from a file that has voice dubbed over the music ?
    mike
  5. Member mats.hogberg's Avatar
    Like reboot says, some filters might achieve something to that effect if the audio fulfils some narrow prerequisities, like the music sounds being left or right channel only, and voice sounds equally distributed left & right. Then it's possible. Unfortunately, in realty the situation is much more complex, that's why the "No".
    /Mats
    I guess i just like thing's that are complex !!!!
    Thanks Mats....
  7. Member mats.hogberg's Avatar
    If you'd like a demonstration of what's (im)possible, take a look at the AnalogX site and the Vocal remover. Try the WinAmp plugin.
    /Mats
    Thanks,And i'm going to take you're word on it that it's not worth the trouble......
    One more thing, How did you add hyperlink in the words (Vocal remover )
    Thanks for all the advice !!! With VirtualdubMOD
    i was able to demux the audio into a wave file. Now comes the hard part in extracting the voices from the soundtrack.....
  1. extract music from bin image?
    By pensioner in forum Newbie / General discussions
    Last Post: 18th Apr 2011, 23:01
  2. need a quick refresher course/ conversation
    By jameskiehl in forum Newbie / General discussions
    Last Post: 18th Mar 2011, 15:20
  3. Problems with VOB Conversation
    By Sundayarak in forum Video Conversion
    Last Post: 7th Jun 2010, 07:37
  4. How to extract music only?
    By UncleBose in forum Audio
    Last Post: 14th Nov 2009, 08:51
  5. Extract special CD-music to harddrive
    By Blå_Mocka in forum Audio
    Last Post: 21st Jul 2007, 06:51
