VideoHelp.com Forum
Results 1 to 11 of 11
  1. i have recently been looking at getting this card but with all the stuff i hear about the audio problems i need to know are it is really that bad
  2. Are you willing to take the chance?
    Check out the PVR-150 forum here: http://www.shspvr.com/forum/index.php
    Cheers, Jim
    My DVDLab Guides
  3. I was looking into this device too but as reboot said are you willing to take a chance? Some people have had success with fixing the audio problem wiht the prerelease drivers. For others the audio problem goes away but then image quality gets worse. If you do buy it make sure the store accepts returns just in case you have problems....
    I have been using the WINTV PVR USB2.0 for some time and have had no problems. IMHO it works great.
  5. Member The_Doman's Avatar
    The audio recording and AGC settings of the PVR-150/500 are now (Finally!) adjustable with the latest pre-beta drivers. (With very little help from Hauppauge..)
    But the latest Pre-Beta drivers have introduced some other bugs and reduced image quality (PAL).
    We are now waiting for Hauppauge to release the official bug-free drivers.
    I am also waiting for over 3 months now..
    Read al about it here:
    http://www.shspvr.com/forum/viewforum.php?f=51
  6. Just spring for the 250 and don't worry about any of this.
    Cheers, Jim
    My DVDLab Guides
  7. Member The_Doman's Avatar
    Yeah, but not so easy to find these days, and more expensive..
    Hopefully they will sort things out now really soon.
    Just let us hope the new drivers are tested thoroughly!, specially for PAL users!
  8. What's the difference in price worth to you?
    I still say get the 250 and go without any headaches, instead of saving a few $ and losing whatever hair you have left
    Be thankful you don't live in Australia, where the 250 is going for over $400.
    Cheers, Jim
    My DVDLab Guides
  9. it is worth alot to me as this card is half the price of the pvr-250 and more expensive than some dvd recorders
  10. Member edDV's Avatar
    If they fix it, I'm buying one.
  11. Originally Posted by buzz86
    Whereabouts would that be?
    The price difference here is less than $35 CDN, and far less than half the price of a cheap recorder.
    Cheers, Jim
    My DVDLab Guides
  1. Hauppage HD PVR
    By xX-Towrd01-Xx in forum Capturing
    Last Post: 19th Mar 2012, 15:15
  2. Capturing from Hauppage USBLive2 WinTV device !!!
    By imperialguy in forum Capturing
    Last Post: 23rd Jun 2011, 16:13
  3. Strange problem with PVR 150MCE
    By nigma in forum Media Center PC / MediaCenters
    Last Post: 5th Nov 2009, 20:36
  4. Replies: 7
    Last Post: 6th Aug 2009, 14:37
  5. Color Bleed on Hauppage WinTV-PVR 150
    By TheBladeRoden in forum Capturing
    Last Post: 14th Jun 2007, 09:05
