VideoHelp.com Forum
  1. I just realized that the picture on all my full screen and widescreen dvd's stretches out when I use this player. I tried zooming in and out but that didn't help. I never noticed this before until I played a dvd-r with a custom made menu. The menu's backround pic was stretched out and the words on the right were cut off. I thought I did something wrong so I tested out some full screen movies I bought and the problem is still there. I did a picture comparison with my older toshiba player and the picture displays fine on it.. unfortunately, the toshiba doesn't support dvd +/- r. My tv is 4:3 and i have that set on the dvd player. Can this be fixed or should I get a new player?
  2. What's your setting on the 727 for your tv type ? is it 4:3 pan and scan or 4:3 letterbox ? If its set to pan/scan thats your problem - set it to 4:3 letterbox and your problem should be solved. If it doesnt work your player may be defective. I've had the 727 for a while and used it on a 4:3 and 16:9 tv and its worked with no problem.
  1. Help with Philips MCD119 problem
    By SteveHarrison1 in forum Newbie / General discussions
    Last Post: 23rd Sep 2010, 16:07
  2. Philips DVP3980/37 Problem
    By Renegade in forum DVD & Blu-ray Players
    Last Post: 2nd Mar 2009, 00:54
  3. Philips DVP5980 upgrade problem
    By snadge in forum DVD & Blu-ray Players
    Last Post: 18th Feb 2009, 09:55
  4. Problem with Philips DVP 5980/12
    By Tinah in forum DVD & Blu-ray Players
    Last Post: 11th Dec 2007, 11:57
  5. Problem writing to Philips dvd-r.
    By jackrussell in forum Media
    Last Post: 13th Jun 2007, 05:41
