I need the best one that will (AND EASIEST) software for editing mp3's or wav files thats not sounding that good. Also one thats good at cuting and pasting the sound different places
Results 1 to 13 of 13
well I know exactly what do you want for I've done so many researches about that.....
In my experience I've found that Sony Sound Forge
is the best,easiest and finest way to edit and cut MP3's and WAV's
and much much moooooooore features....
so I advise you to try it and you'll get exactly what you want....
(((((IMPORTANT: Sony Sound Forge
can make 5.1DD audio with a different birates))))
CAESAR
Goldwave will do most of what Soundforge will do.
Audacity is slightly more limited, but free.Cheers, Jim
My DVDLab Guides
I use Audacity to edit MP3 Files with no problems.
well then I'm having a problems with my head...
SOOOOOORY
ahahhahhahah yall are funny.... but thanks.... i was thinking of giving sony sound forge a try since i am so so at using vegas 5 and was thinking it was near the same thing.....
well but I'm still convenced that Soundforge is the best...
don't u think that geniuses?????
AFAIK all audio editors will convert the file to a wav format file before editing if the file is not already in wav format. That is what Audacity is also doing. So Audacity can edit MP3.
When I was born I was so shocked that I could'nt speak for 18 months.
Try WaveLab
Cheers, Jim
My DVDLab Guides
for features and ease of use i must cast my vote for cooledit/adobe audition. Most applications with that many features require a bit of a learning curve, but i loved cooledit from the first time i used it .
Best audio editing software?
By Hank Kinsley in forum AudioReplies: 20Last Post: 9th Mar 2011, 11:15 -
Audio problems when using video editing software
By luckydoll in forum AudioReplies: 2Last Post: 16th Jul 2010, 21:08 -
What is the best advanced multitrack audio editing software ?
By 3thman in forum AudioReplies: 8Last Post: 11th Dec 2009, 08:45 -
video and audio editing software
By limazita in forum MacReplies: 1Last Post: 10th Mar 2009, 07:26 -
need help: topic - video/audio capturing editing software
By Uebermensch1984 in forum EditingReplies: 2Last Post: 29th Dec 2008, 23:49
