VideoHelp.com Forum
  1. I'm using the latest version and chapterXtrac.
    Doing svcd with two discs you can paste the first 10 capters ect for the first disc but how do you do the second disc(you have to paste in raw mode).
    Using the chapterXtrac guide you have to use h:m mode but this will not paste into vcdeasy.
    Hope thats clear!
  2. You select the starting point as to where the second part of the movie started, something like this:
    Part 1 - represents from 0:00:00 to 0:30:00
    Part 2 - represents from 0:30:01 to 1:00:00
    so when you paste the chapters for the second part, don't start at the begning, start from what represents the second part, and VCDEasy will abjust the chapters accordingly.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  3. Could not find out were you put this info in vcdeasy so I tried it another,you don't have to use raw mode.You can use h:m mode,but what I was doing wrong was right click copy.
    Needs to be ctrl c to copy.
    Anyway thanks for your help Sefy
  4. As long as your problem was solved
    Best Regards,
    Sefy Levy,
  1. AVStoDVD Chapter Problem
    By adyf in forum Authoring (DVD)
    Last Post: 21st Dec 2010, 14:03
  2. mkv chapter file problem
    By Bully9 in forum Editing
    Last Post: 22nd Mar 2010, 18:06
  3. Muxman problem with chapter times
    By lordretsudo in forum Authoring (DVD)
    Last Post: 9th Jan 2010, 07:52
  4. VOB2MPG Chapter Extraction Problem
    By murray666 in forum SVCD2DVD & VOB2MPG
    Last Post: 20th Oct 2009, 03:14
  5. Problem with creaing Menu in VCDEasy
    By haris in forum Authoring (VCD/SVCD)
    Last Post: 16th Mar 2008, 08:17
