VideoHelp.com Forum
  1. Can the DVP642 playback a PAL disc on an NTSC TV? How does the result look? Is there risk of damage to the TV?
  2. Member canadateck's Avatar
    No risk to the TV,I play them all the time,They Look Fine.
  3. I had some trouble at first with a PAL DVD. All I needed to do was to set the DVP642 video settings to NTSC (from System Menu). It played fine afterwards.
  4. hi
    does it have an input to get pal and convert it to ntsc for a ntsc television
    The player will convert PAL to NTSC output if you set the TV output to NTSC in setup menu. That will make it convert everything it plays to NTSC. A word of warning - this player doesn't scale to NTSC but chops off lines to get the output to NTSC standards. I confirmed this by playing a Chinese PAL VCD which is pan and scan and has English subtitles at the bottom of the image. The subtitles were almost completely cut off when watching with this player. If you are watching non-subtitled video, you may not notice. If you are watching anything that is letterboxed, the player will cut off some of the black border, so there's no problem there.
  1. Replies: 19
    Last Post: 28th Apr 2009, 20:44
  2. Philips DVP5990/37 and Toshiba XD-E500 NTSC to PAL question
    By vatkat234 in forum DVD & Blu-ray Players
    Last Post: 19th Feb 2009, 09:12
  3. Playing PAL DVD on Philips DVP3345V and NTSC TV.
    By atarmiga in forum Newbie / General discussions
    Last Post: 14th Feb 2009, 19:31
  4. ntsc tapes pass through pal camcorder into mac for ntsc playing?
    By tozier9 in forum Newbie / General discussions
    Last Post: 7th Dec 2008, 17:19
  5. Philips DVP642 having trouble with X16 discs
    By CaspianCanuck in forum DVD & Blu-ray Players
    Last Post: 10th Aug 2007, 08:49
