VideoHelp.com Forum
  1. Hi. I've got a Sharp DV camcorder which has a smaller version of a 3.5mm microphone input, its supposed to be for a zoom mic that fits on the accessory shoe, but i would like to know if its possible to buy an adapter to use a standard microphone?
    If it helps i do have a microphone from some two way radios of the smaller size and it will record sound (and enable the zoom mic menu) if plugged into the camcorder.
  2. It's probably a mic-in. You can attach a shotgun mic, wireless mic...anything you like pretty much.
  3. Member edDV's Avatar
    To use nice XLR low level 600 ohm mics or to take a low level line feed from a pro audio mixer, check out BeachTek
    http://www.beachtek.com/
  4. Thanks for your replies but the problem is the mic input is not a standard 3.5mm size, it looks the same only smaller (maybe 2.5mm) i really wanted to know if there is a simple "plug this into the camcorder and a standard microphone into this" adapter anywhere? thanks again.
  5. Member drjtech's Avatar
    If you're in the States drop by your local Radio Shack and take a look at their Inline Adapters:
    Inline Adapters
    -drj
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
    --Benjamin Franklin
  1. Windows 7 on Socket A nice OC
    By ocgw in forum Computer
    Last Post: 8th Nov 2009, 06:24
  2. composite via scart socket
    By gb666 in forum Newbie / General discussions
    Last Post: 23rd Sep 2009, 05:53
  3. INTEL 478 socket - 775 socket heatsink/fan
    By blinky88 in forum Computer
    Last Post: 7th May 2009, 10:38
  4. PC AND Xbox360 into the same socket in my HDTV?
    By blueyonder in forum Computer
    Last Post: 21st Apr 2009, 17:49
  5. Headphones into a SCART Socket?
    By vivificus in forum Newbie / General discussions
    Last Post: 16th Sep 2007, 12:24
