Closed Thread
Results 1 to 13 of 13
  1. I got a copy of a DVD and don't know how to play it. There are .VOB .IFO and .BUP files in the VIDEO_TS folder, which isn't an ISO or anything I can mount with D-Tools and play with VideoLAN. Is there anyway I can play this with free software?
  2. Member lumis's Avatar
    Jan 2005
    the remnants of pangea
    i'm going to make the assumption that you have some type of PC-DVD player software installed on your system
    step 1) create iso image of the video/audio_ts folders with imgtool classic
    step 2) mount iso with daemon tools
    step 3) watch with PC-DVD software
    Aug 2003
    You stated your files are in the VIDEO_TS folder so you don't have to make an ISO image. Open your dvd player software and browse to the folder that has your compliant dvd files.
  4. Member lumis's Avatar
    Jan 2005
    i suggested the iso because any PC-DVD software should play it because the iso will be mounted as a virtual drive.. some PC-DVD software will not play from a VIDEO_TS folder on the hard drive.
  5. The only thing I have that can play DVDs is VideoLAN which doesn't seem to be able to play the files individually, but it can play ISOs. I'll check out the isotool that was suggested, thanks
    Are there any other options? How common is it for DVD's to just be unrar'ed into a folder rather than a ISO? It doesn't seem very convenient...
    Anaheim, California
    PowerDVD - Just open the VIDEO_TS folder instead of all of the files inside.
  7. Member lumis's Avatar
    Jan 2005
    powerdvd is not free, there is a 30-day free trial though.
  8. Member monzie's Avatar
    Nov 2003
    The Village
    Use Videolan: Locate the .VOB files in 'QUICK OPEN'
    No2: We want Information.
    No6: You wont get it!
  9. I've tried the PowerDVD and WinDVD demo before and I'm pretty sure they both had some lame limitation where it would only play for 5 minutes or so... was that changed?
    VideoLAN can play the .vob files but I don't know what episode I'm on and I could be wrong but they don't seem in order...
  10. Member lumis's Avatar
    Jan 2005
    http://www.gocyberlink.com/multi/download/dl_file_new.jsp?ProdId=1&lang=ENU
    30-day trial, the only limitation is DVD-Audio with protection.
    Mar 2008
    Canada
    You're ******* stupid, have you ever heard of Pirating a full version? Noob Sauce, GTFO.
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator redwudz
  12. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    WOW!!!!!
    A noob, first post & Pulling up a 3 year old thread for that sweet bit of wisdom
    I dare say you are the one who is
    ******* stupid
