if this is in the wrong forum please accept my apologies.
Can anyone tell me the resolution (# x #) of a 32 inch LCD widescreen tv??
The same as HDTV or whatever format your running though it.
If you mean when hooked into a computer then its going to vary.
Native resolution (the only resolution that actually looks good for that LCD) is probably 1280 x 1024. Resolution of LCD's doesn't get higher with size, just price. If it is a cheap one, ir could be as low as 1024 x 768. It only has to be able to display 720p to qualify as HD, even if it can't display 1080i without compromise. Until they can get true HD and a decent picture quality, I'll stick with my tube.
Most 32 inch LCD TV's are 1280x768 or 1366x768.
we'll be hooking a computer up to it
My 19 inch monitor is better than that. I wouldn't waste the money. Get a good CRT monitor and a HDTV tuner card. You will get a much better picture and more versitility.
42 inch plasma widescreen (16x9 hdtv has native resolution 1024 x 768 (4x3)
By sbt5 in forum DVB / HDTVReplies: 15Last Post: 4th Aug 2009, 21:59 -
Codec for a 52" inch LCD
By GassiusClay in forum Newbie / General discussionsReplies: 4Last Post: 2nd Mar 2009, 21:19 -
What good browser is there for htpc use on a 32 inch lcd hdtv?
By yoda313 in forum ComputerReplies: 14Last Post: 21st Dec 2007, 08:25 -
Which TV tuner playing well with widescreen LCD?
By SingSing in forum Newbie / General discussionsReplies: 1Last Post: 5th Oct 2007, 09:27
