Okay I just picked up a system from Frys with a hauppauge pvr 150 dv & analog capture unit. So I noticed I cannot capture in premiere (analog at least, I don't have a dv camera) so I capped my video via arcsoft's dvd studio program as mpeg and sent it to the premiere to edit. It imports fine but then the audio doesn't come up on the sequence screen or when I render and output it to it's own file. Now I have changed the the playback settings to audio hardware only and dl'ed multiple codecs hoping for a fix, nothing has come up. I am wondering if anyone knows what I can do or any suggestions to resolve this problem. Also I am seriously wondering if Premiere will be able to capture and output video from the DV hardware when I do get a dv camera since this card is capping in mpeg format.
Thanks for your time folks I hope someone can help me out with this problem.
My comp info
http://www.fryssupport.net/fm7750.cfm
First of all, seems that you are not too familiar with Adobe Premiere and Video editing. I assume when you play the original MPEG2 file in arcsoft you have the sound. Try editing with some free demo editor to see if you can import the audio as well. Find out from MPEG properties if audio is included and in what format (Videoinspector?).
Capturing DV will not be affected (this is default).
Yeah I'm a total neb to premiere I'm used to using avid on a mac so this is a whole new thing for me. And yes the audio is present on every other playback forma, also I put the audio in windows movie maker and it played fine in the preview and sequence.
Okay I dled video inspector and this is what I got:
File Name : C:\captured video\20050322-012652.mpg
File Size : 58.9 Mb.
[Movie]
Valid : Yes [MPEG]
Duration : 00:01:26
Movie complete : Yes
[Video]
Resolution : 720x480
Codec : MPEG2
FPS : 29.97
BitRate : 4883 Kbps
Quality Factor : 0.48 b/px
[Audio]
Codec : MPEG Audio 1 layer 2
Number of channels : 2
Sample Rate : 48000 Hz
BitRate : 8 Kbps
You need to convert audio to WAV.
Goldwave or any good audio editor. Check tools section. Convert to wav and import in Adobe or...
get Womble MPEG Video Wizard that will import and allow editing in MPEG2.
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
From DVD to Premiere Pro using Mpeg Streamclip
By rolfwerks in forum Video ConversionReplies: 4Last Post: 3rd Nov 2009, 09:23 -
Premiere Pro CS3 MPEG-2 Compatibility
By cyberboy in forum Newbie / General discussionsReplies: 3Last Post: 1st Dec 2008, 13:58 -
Problems with slowmotion in Premiere Pro 2.0
By chrisal in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 21st Sep 2007, 14:07 -
Mpeg-4 to mpeg-2 for mac/adobe premiere pro......
By macbookuser in forum Newbie / General discussionsReplies: 1Last Post: 4th Sep 2007, 21:48
Statistics
Newest guides
Latest tool updates
New media comments
