VideoHelp.com Forum
Results 1 to 16 of 16
Thread: Princo?
  1. Found this..
    http://www.supermediastore.com/princo-dvd-r-4x.html
    Anyone know if these media are any good?
  2. I'm a Poll Super Moderator johns0's Avatar
    El crapo.
    Ben Johnson-I didnt take any stereos!
  3. Member Sabro's Avatar
    Buyer Beware...Princo seems to be a 99% no no based on a majority of posts around here.
    Sabro
    www.sabronet.com - It's all you need...to know
    Junk.
    Had a client whinning recently about a DVD that wouldn't play on anything and if it did it skipped paused pixelated. I got him to send me the disk and hey presto! princo....or should I say crapo
    There are not 100% bad or they wouldnt make them. Ive used quite a few when I first started burning dvds and they worked fine, scanning them now doesnt show great results but they still play fine.
    A lot of the opinions youll find here are second hand, without actual experience, just second hand info. that some will swear by.
    That being said I wouldnt buy them now, because I have found other brands I like better.
    COPIED OVER 600 DVDS SO FAR
  7. Member lacywest's Avatar
    CompUSA DVD-R are ...
    Media Information
    Region information N/A not a DVD-VIDEO
    Media code/Manufacturer ID PRINCO
    Format Capacity Not Formatted
    Free Blocks 3112960
    Free Capacity 0.00GB(0.00GB)
    Book Type DVD-R
    Media Type DVD-R
    Media Id Code Speed 1.0x 1385KBps
    Write Strategy Speed 1.0x 1385KBps
    Data area starting sector 30000h
    Linear Density 0.267um/bit
    Track Density 0.74um/track
    Number of Layers 1
    I use them in my Panasonic E50S ... DVD Recorder ... to record TV Shows
  8. Member richdvd's Avatar
    Stay away from these.
    These are REAL BAD discs.
  9. Member blinky88's Avatar
    I cannot speak for Princo DVD-R x4 in any other country outside of Australia. At present I know 24 people and myself are using them exclusively and are not having any problems whatsoever. I first stated using them 12 months ago after visiting LordSmurf site (nomorecoasters) at which time, he stated: "he had burned hundreds of them with a 99% success rate" which seemed pretty good to me. He doesn't seem to have that opinion now, however, I have continued to use them and continue to have no problems at all.
  10. wow alright, no princo it is...
  11. Video Restorer lordsmurf's Avatar
    PRINCO, like RITEK, had a short timeframe where the discs were good. That time has passed. Long ago. That was mostly burning 4x discs at 2x also, back when few people had the new $300+ 4x burners.
  12. Garbage. Crap. Junk. Caca.
    Other than that they're fine
    Really, don't go near Princo, no matter how low the price is.
  13. Hmm, I used to get chewed out for suggesting these things erase data after a few months....
    In the future, here are the nifty media opinions:
    http://www.videohelp.com/dvdmedia
  14. Not only were they crap to start with in my Panasonic E50 and TDK burner, many of the ones I did get to record and finalize are now going bad and will not play less than a year later. Stay away from CompUSA Princo junk. Really bad stuff. Apparently those guys will sell anything.
  15. Originally Posted by handyguy
    Two reasons for that - Princo used to be much better (>1 year ago) and the possibility of media losing data once a good burn is achieved is unlikely without some "help", IMO.
    Typical dye, including Princo dye, holds data from 100 to 200 years. The issues with Princo are dye coverage and generally poor fabrication. Things that prevent a good burn from happening. But once it's achieved ...well, when someone suggests a DVD-R "forgets" data, I suspect it's mechanical or heat damage as opposed to the dye itself fading.
    Princo are so crappy, it wouldn't surprise me if the slightest mishandling would do them in. It probably doesn't matter to someone who has one go south on them what the actual mechanism is, but the distinction is important. Our resident media guru agrees. But I guess the important thing, and the one that few people disagree with, is that Princo isn't worth the jewel case it sits in :P
    Here's an interesting little article I posted about a year ago about just how well the dye retains data, and also some misconceptions about the longevity of pressed DVDs.
    http://www.gcn.com/23_5/news/25166-1.html
  16. Member waheed's Avatar
    Princos are certianly bad discs, but i still think Riteks are still good diss even today.
  1. This Old Princo
    By hech54 in forum Media
    Last Post: 16th Oct 2009, 17:01
