Hi.
I have 2 MPEG-2 video clips, which hold the same movie, but they come from a different source (one from DVB-S and one from DVD). As a consequence, the HSV values (colors) of both clips are different. Unfortunalely I have only the first pasrt op the DVB-S clip (1) and the last part of the DVD clip (2). Hence I would like to join both clips.
If I take the same scene, how can I detect which HSV value is used by clip 1 and adjust the HSV values of clip 2 (using VirtualDub) accordingly?
Many thanks.
Thread: Get HSV values
No answers yet ...
Was the question not clear (shall I rephrase?), or is there no solution to this, except trial-and-error?
Thanks.
well in this case the eye is a pretty powerful tool if you dont have a program for color correction
I have used a Histogram filter in the past to see what the individual color levels are. Also the Red/Green/Blue(1.0) filter to adjust the colors individually.
Sometimes also the HSV for rough adjustment. I think there may be some other Histogram filters that would work, possibly better. VD has a lot of filters available. Try a Google search for 'Virtualdub filters'.
Also AVISynth. It has histogram filters and numerous ones for tweaking colours. Plus you can use stackvertical or stackhorizontal for comparing the two visually.
Thanks for the answers. I'll give all that a try.
Recommended compression values for 720p
By Artas1984 in forum Video ConversionReplies: 10Last Post: 29th Mar 2012, 10:19 -
VOB2MPG Correcting PTS values
By dvdmovie in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 15th Mar 2012, 15:06 -
How to get pixel values of MB in x.264
By polovn in forum Newbie / General discussionsReplies: 0Last Post: 2nd Mar 2009, 03:19 -
Help!Original values for Philips dvdr3320v/01
By febius in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2008, 12:04 -
MPEG2Repair results - PIDs values, what do they mean?
By geek2330 in forum Newbie / General discussionsReplies: 3Last Post: 5th Oct 2007, 10:05
