VideoHelp.com Forum
Results 1 to 30 of 40
  1. i found TMPEGenc really easy , but the problem is that i cant get the quality nice! its always blobby and has these weird circly things. they say TMPEGenc has really good quality! but i cant really figure it out , o yea and i put the "DC component precision" to 10 bits and the "Motion Search precision" to Highest Quality(very slow) somebody help me please!
  2. Use average bitrate of 8000.
    Use 2pass VBR.
    Use Noise reduction filter.
    Wait about 40 hours to find out it's still blocky
    Try Mainconcept mpeg encoder or Canopus Procoder Express.
    Cheers, Jim
    My DVDLab Guides
  3. Member sanjayk's Avatar
    tony,
    how is the qualty of your original file? If you encode the quality WILL go down to some extent. That is the bottom line. The trick is to keep it as close to original as possible by tweaking the various settings an encoder provides. IMO you should leave the DC component setting to 8 if not encoding for DVD.
    For better quality use higher bitrate as already suggested by reboot.
    But hey reboot, the 40 hours wait ... is too much battering for god ol TMPGEnc Already one comparision thread is going around.
    When I was born I was so shocked that I could'nt speak for 18 months.
  4. Member mats.hogberg's Avatar
    Well, given a 2-3 year old box, and motion search precision on highest, 40 hours doesn't seem that out of proportion But then, highest shouldn't be used at all, since it doesn't make any visible difference in the end product from high or even lower, while taking an enormous amount of time...
    /Mats
  5. The neck of the bottle here is the Noise Reduction filter. If you thought TMPG is slowly with Highest motion search precision, thick Noise Reduction to learn what is really slowly .
  6. Originally Posted by mats.hogberg
    Never use TMPGEnc filters. Filter source thru VirtualDub or AviSynth, and frameserve.
    Wise words indeed!
    Cheers, Jim
    My DVDLab Guides
  7. i actually tried
    "Use average bitrate of 8000.
    Use 2pass VBR.
    Use Noise reduction filter"
    took about 4 hours Oo , avnt checked it yet though
    and to answer sanjayk:
    the quality is really good on the originial (the perfect quality you see now adays) i tried doing just the needed settings for a dvd *720x576 , gop structure etc* and i left the motion search to normal and the DC component to 8. and it still came out crappy.
    but i should get those thingies that reboot told me to get
  8. Set DC component to 10.
    Cheers, Jim
    My DVDLab Guides
  9. Originally Posted by reboot
    Use 2pass VBR.
    wow i tried that combined with mine and the quality came out close to perfect! thnx
  10. ermmm...i have another problem.
    whenever i check it , it always says
    "WARNING: NOTHING TO BFRAME DECODER LAG"
    and i find it kinda annoying , does anyone know what i done wrong?
    (the video works perfectly fine but it says that on the very 1st frame)
  11. I get this sometimes because of the high bitrate.
    Cheers, Jim
    My DVDLab Guides
  12. oic . so theres no way of preventing it from happening unless you lower the bitrate?
  13. Member sanjayk's Avatar
    Increase the DirectShow filter priority in TMPGEnc to max so that it reaches the top of the list. Then encode.
  14. Well, this come from the way XviD decoding the first frame in some avis. Why it is so I don't know, usualy I cut the first frame with avisynth and the error is gone.
  15. woah?! the files came to 3.16gb and 3.20gbs! if i put the 2 files together it wouldnt be able to fit into my discs?!
  16. ermm...how do i use avisynth . i downloaded it from the site and i cant find the program to start it. i done this before ages ago but i dont remember what to do
  17. Member mats.hogberg's Avatar
    Bitrate calculator.
    /Mats
  18. You said you wanted the best quality.
    If you use high bitrate, needed for premium quality, you get very large mpg's.
    Buy a larger hard drive
    If you want to get this onto dvd, then there are other ways to (hopefully) keep the quality up, and decrease filesize. In the end, bitrate=quality, higher is better, and you sometimes have to live with a quality loss to get the amount of video you want (in running time) onto one dvdr.
    Cheers, Jim
    My DVDLab Guides
  19. true , but i never knew it would become such a large file. i got it down to 2.4gb now. (i dont really mind having big files but im just worried it wont fit into my dvdrs)
  20. DVDR holds 4.3 gig. Make it 4.2 to leave room for authoring.
    Learn how to use the bitrate calculator
    If the authored dvd is larger than the disk, use DVD Shrink to make it fit.
    Not recommended, but it does work.
    Cheers, Jim
    My DVDLab Guides
  21. ok thanks , erm...the file is split into 2 so what should i do? should i split the average bitrate?
  22. Dual layer discs hold 8.7gb (?) worth it if its a pristine prestige project and you want to avoid
    The electronic components of the power part adopted a lot of Rubycons.
  23. Member mats.hogberg's Avatar
    Add the time of AV1 and AVI2 together. Get the bitrate to use from the sum. Encode each AVI to mpeg with this bitrate.
    /Mats
  24. hm...thats what i did and it came up to 3.16gb and 3.20
  25. and i joined both of the files together and encoded it like that. but i always seem to get an error something about a line 2-3 hours through encoding
  26. That's because of a fault in whatever program you used to join them.
    DON'T join them. Encode separately, join during authoring.
    Cheers, Jim
    My DVDLab Guides
  27. kk , i just need to figure out what to change the average bitrate for both files to!!
  28. What are the running times of the two videos?
    Add them together. Input into the bitrate calc.
    Cheers, Jim
    My DVDLab Guides
  29. kk cool cool. it worked ! found out there was a custom thingy. all i need to know now it how to work avisynth!!
  1. avi looks perfect one play, grainy the next ...
    By Blackout in forum Capturing
    Last Post: 18th Mar 2011, 07:05
  2. DVD to perfect AVI?
    By bagmand22 in forum DVD Ripping
    Last Post: 18th Nov 2009, 09:52
  3. Recording series off sattalite tv with perfect quality DVD
    By WildCatRaze in forum DVD & Blu-ray Recorders
    Last Post: 3rd Mar 2009, 12:40
  4. Replies: 1
    Last Post: 25th Feb 2009, 23:31
  5. .AVI to DVD with Nero, Almost perfect except last 15 mins.
    By dl2500 in forum Newbie / General discussions
    Last Post: 4th Nov 2007, 17:43
