VideoHelp.com Forum
  1. hi......great site here!!
    i have an intel "camera pro" pc cam. the software it comes with called "create and share" is just garbage. it has snapshot and video record functions. what i'm interested in is the video. the snapshots it takes are fine, but the video quality blows.......15 fps and 1/3 of the frames are redundant.
    i've tried a number of progs that say "video capture" or recorder, but they all make you use your existing software. in other words, when you want to capture video from your cam, it won't do it directly. it only opens create and share for me.
    so what i want to know is if there is a program that will record video right from my camera, bypassing any other vid recording software on my pc. i tried the page here that shows various capture devices/methods, but none seem to fit my needs. but then i'm a bit confused with some of the terms used.
    sorry if i sound ignorant about video........but i am !!
    anyway, my main reason for wanting a prog to do this is quality. i want much better video quality than the create and share software will allow.
    thanks.....
    _________________
    Dazco
    <font size=-1>[ This Message was edited by: dazco on 2001-12-10 18:32:45 ]</font>
    It may not be possible for the camera to do the desired functions.
  3. actually, i just downloaded something called virtual dub while waiting for a reply. i didn't think it would work by the description, but it does ! as for the quality, it seems a lot better, but i just tried it a miute ago. still open to suggestions tho. i'll try as many as i can till i find the best one.
    check also the Studio 7 software that is capable to capture from webcams analog capture cards digital video capture cards (1394 fire wire) and graphics cards with TV in options.
    I have a Intel PC Pro camera. I can capture video from this camera using the Ulead Video Studio 4.01. The quality of the captured avi is very grainy and not good at all!
  1. recording from a cam in front of stage
    By smartel in forum Audio
    Last Post: 7th Jul 2011, 08:45
  2. My Bass in a Cam Recording is to loud ?
    By picklepie90 in forum Audio
    Last Post: 1st Mar 2011, 01:04
  3. Which is the best software solution to accomplish a 2 cam edit
    By jwalter007 in forum Newbie / General discussions
    Last Post: 26th Feb 2010, 06:43
  4. Versatile video recording software MAC/PC?
    By clancey in forum Capturing
    Last Post: 2nd Nov 2009, 23:27
  5. Software For Recording Flash Video
    By subsync in forum Newbie / General discussions
    Last Post: 20th Jul 2009, 05:20
