I usually convert from PAL to NTSC 526x480 to 352x480
I use TMPGenc, when encoding must I use 2:3 pulldown??
I usually encode to 23.97 video and audio.
When I do use it will it cause audio sync problems with some files?
I use DVDLab and I notice everytime you put a file in it says 3:2 pulldown to the file.
If I did not use the 2:3 pulldown when encoding with TMPGEnc what problems will I encounter??
Thread: when to use 2:3 pulldown???
No, but you'll have to apply the pulldown flags somewhere along the line (if you encode to 23.976 fps). I prefer to add the pulldown flag after I have finished encoding using PULLDOWN.EXE.Originally Posted by BCAESE
No... (well, it shouldn't).Originally Posted by BCAESE
As I said earlier, a pulldown flag will have to be added sometime. If DVDLab does it on its own, then just feed it 23.976 fps video.Originally Posted by BCAESEICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
I guess if it is added when encoding or when in DVDlab it doesn't matter.
Correct me if I'm wrong.
I use DGPulldown (same idea as Pulldown.exe, but more flexible) mainly because it is faster than DVD Lab's pulldown process.
2:4 Pulldown
By supervehicle in forum Video ConversionReplies: 23Last Post: 3rd May 2011, 16:53 -
Correct pulldown or not
By carlmart in forum Video ConversionReplies: 2Last Post: 1st Feb 2009, 19:25 -
3:2 pulldown?
By blizzery in forum Video ConversionReplies: 3Last Post: 24th Jul 2007, 06:38 -
Using pulldown
By MysticE in forum Video ConversionReplies: 2Last Post: 14th Jul 2007, 03:25 -
Film Pulldown
By Soapm in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 18th Jun 2007, 12:20
Statistics
Newest guides
Latest tool updates
New media comments
