VideoHelp.com Forum
  1. I used to Tmpgenc to rip and convert the vobs off of a dvd. Everything worked great, quality was great, the only problem I had was when someone is running or their is fast motion (action) I see these fine lines in the video. I'm sorry for the lame discription but that is the best way I can put it. What am I doing wrong? Does anyone have a better program I can use to rip a dvd into a high quality mpeg or avi. I am trying to rip music videos off of a dvd so it doesn't take long, but I just want those damn lines to disappear.
    ANy help would be appreciated
    thanks
  2. You are probably seeing scan lines from interlaced video. You would need to de-interlace the video to get rid of this.
    I believe you can edit the video using a free program like Virtualdub to do the de-interlacing (use the smart de-interlacer filter). The free MPEG decoder FlaskMPEG might include some de-interlacing capability, although I am not sure about this.
    There is also a commercial tool, Cinematize, that does the extraction from your DVD, decoding of the audio and video, and de-interlacing of the video all in one operation.
  1. Weird lines show when playing DVD
    By tlafo in forum DVD Ripping
    Last Post: 28th Feb 2011, 00:31
  2. using tmpgenc author how can i include some 20 videos in the menu?
    By sumeshkri in forum Newbie / General discussions
    Last Post: 27th Oct 2010, 03:07
  3. weird problem with mpc while playing videos
    By CheekyKid in forum Software Playing
    Last Post: 23rd May 2009, 06:38
  4. Replies: 1
    Last Post: 20th Aug 2008, 02:41
  5. Replies: 3
    Last Post: 11th Jun 2008, 12:50
