VideoHelp.com Forum
  1. Hello, I have just bought a DVD recorder (the Sony GX300). If I save a film which is broadcasted in 5.1, then copy it to DVD, is there anyway in keeping it 5.1 because my first effort played in Dolby Prologic.
    Is there a setting or is it a general thing that this cannot be done ?
    Paul
  2. How is the audio connected to the DVR?
    Unless this connection is digital, no 5.1 capture is possible. Unless you have 6 channel input on the DVR.
  3. Thanks for all your quick replies.
    Here is my set up
    I have Sky Plus
    I have the Sony DVD Recorder connected to the Sky Plus Via Scart
    I can record from The Sky Plus onto The DVD recorder no problem but only in stereo.
    Is there anyway of recording in 5.1 ?
    Do I need to connect both devices with an optical ?
    I hope that is clear ?
    Paul
  4. Originally Posted by paulwilko
    The Sky+ box will only give 5.1 audio through the optical out. You would need a recorder that has a digital audio input (optical or coax via converter). I know the Sony has an optical audio output, but does it have any kind of digital input?
  1. Sky+ HD to PC
    By BIGD22 in forum DVB / HDTV
    Last Post: 27th Sep 2011, 13:59
  2. Transferring Sky+ recordings to PC
    By grandsire02 in forum Newbie / General discussions
    Last Post: 21st Nov 2010, 15:37
  3. Problem capturing sky digibox recordings
    By scamperoo in forum Capturing
    Last Post: 19th Oct 2009, 09:32
  4. Sky + And/Or Sky HD Recording To Pc With DAZZLE
    By akenny01 in forum Capturing
    Last Post: 7th Mar 2008, 18:02
  5. Sky+ to PC
    By pjvw in forum Capturing
    Last Post: 13th Sep 2007, 12:00
